Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 06-04-2007, 12:50 PM   #1
vplath
Profile:  Nunica , Michigan
Formaldehyde
Has any one ever tested the air quality in there Air Stream motor home or trailer for formaldehyde? Apparently it can is used in the adhesives for cabinetry and other wood structures. When the units are subjected to high temperature or humidity the formaldehyde out gases into the air. There is an article at the Sierra Club called “Toxic Trailers”. Any comments?
vplath is offline   Reply With Quote
Old 06-04-2007, 01:21 PM   #2
nickcrowhurst
Profile:
I haven't tested my trailer, but there is a test kit for $89 pus laboratory fees here:
Testing formaldehyde: Formaldehyde Test/sampling kits, formaldehyde testing kit
I keep down the potential risks from formaldehyde gas by sealing MDF and similar particle boards after machining, and before bringing them into an enclosed environment.
If I were to buy a new trailer, I would rely on normal airing and ventilation to disperse any initial high concentrations.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 06-04-2007, 02:00 PM   #3
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
Come to think of it, I do recall seeing many fairly well-preserved older folks traveling in airstreams–maybe its the formaldehyde.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is online now   Reply With Quote
Old 06-04-2007, 02:24 PM   #4
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Hello Victor -- Welcome to the Forums! There are other threads to read if you search on the keyword formaldehyde. I think a thread by janetb, Newer model odors/fumes, said a lot for lessening outgassing within the first season or so. She posted in a different thread later stating that it had disappeared after a minimum number of months (2-3? I don't recall exactly).
Adhesives with any plywood or particle board are said to contain formaldehyde unless specifically stated otherwise -- then there would be other constituents. This is not a lot different than volatilization of plasticizers with 'new car smell.' A very sensitive asthmatic might be affected but it doesn't persist for long. I don't think anybody buying a minimally used Airstream would be worrying about this at all.
From a long time Sierra Club-er!
Old 06-04-2007, 02:44 PM   #5
Lumatic
Lumatic's Avatar
Profile:  1971 25' Tradewind
1962 28' Ambassador
Estancia , New Mexico
Formaldehyde ain't all that bad. After all they mix it in beer to give it more head!
The Truth is Out There
Formaldehyde Bob J. Mariano Our Community 20 07-28-2006 04:21 PM
Chemical emissions in new trailers? ALANSD Off Topic Forum 7 07-27-2006 01:27 PM
Help, where's that smell coming from M&M CAPECOD General Repair Forum 28 07-01-2005 01:11 PM
Toilet chemicals gwsullivan Waste Systems, Tanks & Totes 33 02-24-2005 01:28 PM
Dump station follies jcanavera The Rally Zone 34 08-21-2003 04:24 PM
