Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 05-14-2002, 09:20 PM   #1
airstreammotorhomes.com
1985air345's Avatar
Profile:  Charleston , West Virginia
Send a message via AIM to 1985air345 Send a message via Yahoo to 1985air345
Flushing Black Water Tank
We discovered through normal operations that our septic system smelled AFTER we dumped our tanks. Normally you would think a full tank would smell but I guess the water and chemicals hold the odor down. We ended up dumping the black water and then filling and dumping the black water tank three times with a hose. That seemed to help.
What is the best way to clean the black water tank?
Here is something I saw in the Camping World catalog.
http://www.campingworld.com/browse/s...=7332&src=UPSE
Fred H.
No Airstream Anymore..
Fred's Airstream Archives - Motorhomes
Fred's Airstream Archives - Trailers
1985air345 is offline   Reply With Quote
Old 05-14-2002, 10:58 PM   #2
JW84345's Avatar
Profile:  1969 27' Overlander
, Michigan
Hi Fred,
It is better to let the tank become full or nearly so before dumping. This provides a good flow to flush the tank contents. If possible (i.e. when dumping with a full hookup) I hold the valve open on the toilet for a couple of minutes to flush clean water through the tank before closing the dump valve. I make it a point to do a fresh water flush through the tank at the end of every trip. Regardless, "matter" does accumulate over time and will become odoriferous. Use of tank cleaning products periodically is a good idea. Usually they recommend you fill the tank, add the solution and drive to slosh the contents, then dump.
JW84345 is offline   Reply With Quote
Old 05-15-2002, 09:05 AM   #3
GA Airstreamer Air_005
Profile:  North , Georgia
Send a message via Yahoo to ALANSD
we were told to let it get at leat 3/4 full before dumping, and then we use a jet spray wand to clean it out when totally empty.
I run clear water back in with some Odorloss, and leave a few gallons in there then. Same for the grey tank, I leave a few gallons in there except when winterized, which i don't guess you have to worry about too much.
Old 05-16-2002, 03:59 PM   #4
1985air345's Avatar
I do let it fill up to get the 'power flush'. What I was missing was the rinsing part. I will make arrangements to do that on a regular basis.
Fred H.
Modified black water tank Marlboro Mafia Waste Systems, Tanks & Totes 13 03-13-2004 06:31 PM
Black Water Tank David Hall Waste Systems, Tanks & Totes 3 12-28-2003 08:24 PM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 08:59 PM
Replacing Black Water Tank Tamara Waste Systems, Tanks & Totes 15 06-18-2002 11:45 PM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 05:17 PM
