Old 02-02-2010, 07:01 AM   #1
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Flooring
Hello all, I have never owned a motor home so I will ask here. A buddy has a newer coach and wants me to remove the carpet and install ceramic tile throughout. 12x12's I think. There is a mid section that already has it but I told him I didn't think it would hold up due to frame flex. Can this be done. Robert
bertro is offline   Reply With Quote
Old 02-02-2010, 07:51 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
I find it hard to believe that a manufacture would install ceramic tile in a MH or trailer.
I would look at it more closely to see if it is in fact ceramic.
Consider Armstrong man made wood. Ease if installation compared to other such products. I have had it installed in my trailer for 4 years now.
2004 Excursion 4x4
Old 02-02-2010, 08:45 AM   #3
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Thanks I have yet to look at it. I also find it hard to believe. Robert
Old 02-02-2010, 09:57 AM   #4
cameront120's Avatar
1972 25' Tradewind
Unless you want to replace cracked tiles and redo the grout after every trip, I wouldn't bother with ceramic tile in a moving vehicle - too much flex.
Any material that can be installed as a floating floor, without adding a lot of weight, would be ideal.
North Vancouver, BC
Old 02-03-2010, 03:10 PM   #5
myfirstrv's Avatar
2000 35' Land Yacht XL w/slide
Vermilion , Ohio
I have an Airstream 2000LY with ceramic,
"Dont DO it"
We want to take it out and Use a "Pergo" type floor
myfirstrv is offline   Reply With Quote
Old 02-12-2010, 06:16 AM   #6
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
I took out the carpet and replaced with the Lowes laminate Swiftlok Plus. The hand scrapped Hickory is a nice match to the existing wood. The Plus has the foam backer preinstalled. This was an easy DIY job and the result is very nice indeed. I'm still due to trim out and have the materials but limited time. When I finish I'll post photos.
What is interesting is that most of the time the floor is covered with the putting mat material used for testing golfers on the SAM PuttLab setup in the bus. Nice floor rarely seen.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
flooring silverbeauty Floor Finishes 5 05-14-2009 09:11 PM
new flooring jpeterman General Interior Topics 1 04-19-2009 07:09 PM
flooring rv-n Floor Finishes 2 01-27-2009 05:06 PM
New flooring liz1300s Repairing/Replacing Floor &/or Frame 7 08-15-2008 10:23 AM
Flooring Fun-Lovin Floor Finishes 8 09-09-2003 11:15 AM
