Old 08-01-2014, 10:28 PM   #1
ALBUQUERQUE , New Mexico
Floor Plans and Specs. for older Airstream Models
To All,
Where can I find information on the older floor plans?
I'm beginning my search for my "new" Airstream and would like to narrow it with viewing floor plans, specs., etc.
Any help?
Permit Bob
Permit Bob is offline   Reply With Quote
Old 08-01-2014, 10:49 PM   #2
pbearsailor's Avatar
Port Hadlock , Washington
Document Archive - Airstream
Cheers,
Steve
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 08-02-2014, 08:42 AM   #3
Perfect!
Thanks a bunch for the info.
"Bob"
Old 08-02-2014, 09:16 AM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
The Vintage Airstream site is a good resource too. Not too many floor plans but lots of pictures and other information.
Aaron
WBCCI #XXXX AIR #2495
Old 08-02-2014, 10:14 AM   #5
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Since these old birds are getting rarer and can be costly to maintain, you may consider floor plan a secondary issue. Condition of the unit and general model preferences should be higher on the list. An example would be, do you want aluminum skin v/s fiberglass? This would be higher on the list of deciding factors. Most of the AS motor homes will share some generalities in terms of floor plan. Even the 90's LY had close approximations compared to the 80's classics. Some are flipped from side to side and some will have queen beds while others will have twins but for the most part they have a pretty common layout. Not saying that there aren't differences, but I would personally sacrifice the ideal layout for one in prime condition and work around or modify the layout as needed. I would never consider a purchase site unseen. Most sellers will have detailed pictures of the inside/outside of the unit. In the end you need to inspect the unit very carefully before the purchase. If you need someone to help with the inspection, then there are services out there to assist you in this. There may even be an AS forum member local to the area that can help out. Just food for thought.
92landyacht is offline   Reply With Quote
Full timing and floor plans norfla71 Full-Timing 16 12-18-2013 06:30 AM
2012 Airstream current available models and Floor Plans Colonial Airstream Commercial Listings 11 10-08-2011 09:24 AM
Older 25' Models and Their Weights? Artizen Our Community 6 09-14-2010 08:25 AM
1985 and on floor plans davidz71 Airstream Trailer Forums 6 12-31-2003 08:13 PM
Older Model Airstream Trailer Specs docbluedevil Our Community 2 10-01-2003 06:28 PM
