Old 08-16-2010, 05:49 PM   #21
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Originally Posted by blkmagikca View Post
As for the Jake brake (or extarder, also called an exhaust brake)
Probably a typo, but the word is "retarder".
It's 30+ years since I drove anything with air brakes, but what I remember is do not dump all your air! That means not to keep hitting the brake pedal over and over.
Gene
Old 08-21-2010, 12:42 AM   #22
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Actually, the metal plate on the dash which has the switch for the Jake says "Extarder".
You still have to keep an eye on the air pressure, and watch that it doesn't drop below 90 psi - max, as you know, is 128 psi. Properly using the Jake when going downhill will definitely prevent your dumping your air.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 08-21-2010, 06:10 AM   #23
1995 36' Classic 36
Orangevale , California
Got it and drove for a day now around highway and surface streets. Got the hang of it pretty quickly. The steering does seem wobbly so the steersafe is something i may look into.
It's got a Pacbrake, which is the exhaust brake. It's automatic. No separate pedal or switch. I suppose the only way to tell its working is to release the gas pedal and the speed drops? PO says it doesn't activate until going at least 30mph.
Took it for an alignment and the tech said I had hydraulic brakes. So what's with the knob I use to set the brake and the swoosh that goes along with it?
Lots to learn, found out today about different sewer hose fittings sizes...after i bought a kit. Back to Camping World.
Thanks for the replies, it's been great preparation.
Gary
Pomfritz is offline   Reply With Quote
Old 08-21-2010, 07:26 PM   #24
Master of Universe
Gene's Avatar
Sounds like Extarder is a name used by the manufacturer for an exhaust brake. Retarder is more inclusive name for a variety of braking systems: http://en.wikipedia.org/wiki/Retarde...al_engineering)
Gene
Old 08-21-2010, 09:43 PM   #25
Registered User
1998 34' Excella 1000
1995 36' Classic 36
Spencerville , Maryland
Images: 14
Wow, all good advice!
GREENovaters is offline   Reply With Quote
Old 08-22-2010, 10:47 AM   #26
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Gary
Your brakes are air over hydraulic - the actual brake mechanism is hydraulic (master cylinders and wheel cylinders, but instead of having the brakes mechanically activated by a brake pedal with vacuum assist as in most cars, your master cylinders are activated by air pressure. So your brake pedal is an air valve (mine is a treadle that looks just like the accelerator) that allows air to activate the master brake cylinders. Your parking brake is spring activated and is inboard either on the drive shaft or the axles. The parking brake is released by air pressure, and cannot be released unless there is a minimum of 50 psi of air. One way to test this is to stop on a level place, place the transmission in neutral and turn off the ignition. Then, without pulling out the parking brake (the yellow square-shaped valve on your dash) pump your brakes to dump the air. Watch the air pressure gauges, and you should see that about 50 psi, the yellow parking valve will pop out. So the whoosh you hear when you pull out the parking brake knob is the air used to release the parking brake being let out so that the spring can set that brake.
There is an air compressor attached to your engine which supplies air pressure to both the brakes and the turbo charger. The air for the brakes is pumped into a 3-chamber tank - the first is the input tank, followed by a primary and secondary tanks. There are one way valves that allow the air to flow from the input to the primary and then to the secondary. The primary tank is the place where any moisture in the air is precipitated. The spitter valve of that tank is the one you hear when 128 psi of air pressure has been attained - it spits out any precipitated moisture.
The primary tank and the secondary tank activate the front and rear brakes - the secondary one (I believe) also provides air to release the parking brake.
The PAC brake (AKA Jake brake) is an air activated valve that partially blocks the engine exhaust where it leaves the manifold to provide back pressure to use as an engine brake. When the PAC brake is engaged, the accelerator is disabled (in my rig) - in your rig, the PAC brake will disable when the accelerator is enabled.
I know that this sounds a bit complicated - it did to me when I first got my LY, but having taken the air brake course for my drivers license, I now understand how it all works. One mechanic told me that the Pac brake was a "use it or lose it" issue - if it is not used at all, the mechanism will seize. I use it whenever I am slowing down or coming to a stop. In your case, having the newer Allison transmission that is automatic.
Enjoy your LY - they're well built to last a long time with proper maintenance.
VE3JDZ
AIR 12148
WBCCI 8080
Old 08-30-2010, 08:50 PM   #27
1995 36' Classic 36
Thanks for the info. Now i know what the front and rear air pressure guages are for! I thought it was for air bags or?
So we are nearing the completion of our trip back, nearly 2,000 miles. Wife and I have split the driving and man does that help. She loves driving it and is learning fast on the manuevering. Aside from the fact that we damaged the steps when they deployed while driving, bentsome lower panels while getting into a tight camp space, had an aux fan on the radiator bust a flimsy plastic mount and punture it, lost a starter due to massive oil collecting in the flywheel housing, needing to replace the rear main seal which cuased the oil biildup it, it's been a great anf uneventful first shakedown cruise.
After the repairs the rig handled crossing the mojave nicely and the trip up and down the grapevine outside of LA went smoothly. Engine temp kept in the 180 (mostly) to 200 range. Oil pressure right about 58 psi
Old 08-31-2010, 12:30 AM   #28
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Uh, the auxiliary fan you're talking about is to cool the condenser for the air conditioner - the radiator is in the back. A word of warning, if the fan to cool the condenser doesn't function, your dash a/c will stop working.
Sounds like quite the shakedown. Reminds me of my first trip from Ontario to Arizona 2 years ago - mega bucks because proper maintenance had not been done. "Proper" is the operative word - until I found competent techs to do the work.
I, too, had the rear engine seal replaced a couple of months ago. However, the only hassle I had was that Cummins initially didn't supply the correct gasket between the exhaust manifold and the jake brake.
VE3JDZ
AIR 12148
WBCCI 8080
Old 09-01-2010, 08:32 PM   #29
Registered User
1995 36' Classic 36
Images: 14
Driving and enjoying your AS Classic Pusher 36
So, how was your drive home after all? I am currently on my way back from Florida with my newly purchased 1995 Classic Pusher 36 and am loving everything about it! Here is a picture of it parked amongst some boats at the marina I stopped at to visit with relatives. The term "Land Yacht" would fit it don't you think so?
full-time winter living problems, questions by college girl (freezing temps, furnace) icedcacti Winter Living 30 08-24-2010 09:07 AM
Full time living/driving helpful advice please tjean45 Full-Timing, Winter Living & Workamping 6 09-20-2007 05:46 AM
First time A/s & Hensley questions MM&MM Hitches, Couplers & Balls 11 06-13-2006 11:03 PM
full-time AC questions Kinder Electrical - Systems, Generators, Batteries & Solar 6 08-27-2005 04:15 PM
Henschen - questions on production time / shocks ND-AMBASSADOR Axles 7 05-05-2005 08:05 PM
