Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 09-09-2003, 06:00 PM   #1
Send a message via Yahoo to lido&linda 85/345
entry door handle
Can someone tell me how to take the door handle off?I'm trying to fix the dead bolt and doorbell. I loosen the two screws on the side plus the inside knob inside,but the handle wont budge,I'm afraid to dent the alluminium skin.Help!!!
lido&linda 85/345 is offline   Reply With Quote
Old 09-09-2003, 06:31 PM   #2
Entry Door Handle
Just did this on my 86 - 345.
In addition to what you've done, remove the 3 screws on the inside faceplate and the whole assembly will come apart; half to the inside and half to the outside.
If this fails, get a bigger hammer
Good luck.
Jeff
jthew1 is offline   Reply With Quote
Old 09-09-2003, 07:44 PM   #3
I guess I have to cut the thin wood panel to access the inside screw?
Old 09-09-2003, 07:45 PM   #4
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Lutz , Florida
Images: 21
Send a message via AIM to thenewkid64 Send a message via Yahoo to thenewkid64
The inside screws sould be on the chrome plate that has the door lever inside on it.
There should be no cutting involved.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 09-09-2003, 08:18 PM   #5
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
I have the same issue on mine and I think I know what you mean...there is no access to the deadbolt door handle from inside the coach. I'm wondering how to do this too. The release handle in the door itself has three screws to remove and it comes apart, but the handle has no visible fasteners other than in the door latch in the frame.
I'm following this too as I need to replace the deadbolt cylinder in mine.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 09-10-2003, 05:27 AM   #6
Dead Bolt Handle
OH! I think "thenewkid64" and I misunderstood and have led you astray.
You're trying to remove the deadbolt handle NOT the entry door handle.
That does looks like a real challenge. I dunno, but maybe there is someone on the forum who can help.
Old 09-10-2003, 11:10 AM   #7
jthew1 is right,its the dead bolt outside handle I'm tacking about.Its the one that houses the deadbolt on top and the doobell push switch on the bottom.
Old 06-14-2006, 02:06 PM   #8
1983 Airstream 300
fwiz's Avatar
I need to service my entry door schlage deadbolt too. (1983 Model 300)
Did any of you have success with your attempts?
How did you do it?
I am thinking that I may have to remove/cut into interior skin to get access.
fwiz is offline   Reply With Quote
Old 06-14-2006, 03:13 PM   #9
ibedonc's Avatar
1983 31' Excella
Caldwell , Texas
My 83 Excella was missing the GRAB Handle and lock , PO said someone broke into
I just got new parts to day , so maybe we can help each other , Service manual state you have to remove inside panel and on my new handle is 4 STUDS , I mite be missing more parts ?
ibedonc is offline   Reply With Quote
Old 06-15-2006, 08:47 AM   #10
1983 Airstream 300
fwiz's Avatar
I don't know if your parts and my parts are the same.
do you have to take the interior skin off to install it?
Old 06-15-2006, 10:36 AM   #11
ibedonc's Avatar
1983 31' Excella
Caldwell , Texas
yes you do
Old 06-26-2006, 09:08 PM   #12
ibedonc's Avatar
1983 31' Excella
Caldwell , Texas
well I have my handle installed , I even backed it with .125 alu sheet for added strength
my only problem is I have wires for a doorbell , but no idea were it runs to , and no doorbell found in the normal locations, I guess I could run a new wire down the wall and under edge of carpet to power panel and put me a homedepot version in .
Old 06-27-2006, 09:58 AM   #13
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
This thread shows the location of the doorbell.
http://www.airforums.com/forum...ese-16223.html
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 06-27-2006, 01:51 PM   #14
ibedonc's Avatar
1983 31' Excella
Caldwell , Texas
my doorbell is not in any of the stated places , so I am doing the homedepot thing
also here is a picture of my grab handle repair , still need to clean it up
Old 06-27-2006, 05:46 PM   #15
guy99's Avatar
Images: 16
Jeez,
Sorry I was wrong about the doorbell location.
Where to get keyless entry code? 0557 Our Community 23 10-08-2017 10:42 PM
Entry door hinge TomW Doors & Locks 35 07-17-2008 07:04 AM
Entry Door Lock Set Hunt ends at Inland Grady White 1959 - 1965 Ambassador 3 12-16-2004 09:08 PM
Cheapest place to find entry door handles??? tin can luv Doors & Locks 0 02-02-2004 10:20 AM
How do you fix the entry step. rdm Airstream Motorhome Forums 2 07-14-2002 09:16 PM
