Old 03-19-2015, 12:08 AM   #1
morlach's Avatar
Electrified 325 Chassis
I have a strange problem. While I was doing some work under my 325 I discovered, that my bumper and parts of the chassis were giving me a mild shock. Has anyone else experienced this phenomenon? Obviously there is a short somewhere. I unplugged the shore AC and the shocks stopped. I am thinking that this is going to be potentially hard to track down. If anyone has seen this and found the problem, it might give me some places to start checking.
morlach is offline   Reply With Quote
Old 03-19-2015, 12:23 AM   #2
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
First place to check is the outlet for correct polarity.
Then check the RV power cord for correct polarity.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 03-19-2015, 12:32 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Might be hard to track, and it might be that your neutral and hot wire are crossed in the plug OR In the receptacle you plug your trailer into.
First of all when trying to address this DO NOT BE THE LINK TO GROUND.
Do not touch the trailer and any ground at the same time EVER until the issue is resolved.
I am going to emphasize that in this condition, touching a ground and the trailer at the same time can be DEADLY.
Get a volt meter, and with the trailer UNPLUGGED turn off ALL trailer circuit breakers. touch one lead to a KNOWN good ground (the ground prong in an electric receptacle at your residence SHOULD be good), and touch the other to the trailer skin.
If you have voltage, either the trailer plug or the receptacle wiring is wired wrong.
If there is no voltage, WITH THE TRAILER UNPLUGGED, flip the breakers on one at a time, and when you are safely out of the trailer plug it in and check the skin for voltage. Continue the process until you find the offending circuit.
There is some danger here, if you are the slightest bit unsure of what you are doing, hire an electrician. Just putting a hand on the trailer in some circumstances can be lethal.
My bet is that the problem is going to be in the plug or receptacle.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 03-19-2015, 12:44 AM   #4
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
In short, on a 120 volt circuit, there should be NO current between the ground and neutral prongs in a receptacle, and there should ALWAYS be 120 volts between the ground prong and the hot prong.
If this is not the case something is wired wrong.
In a regular non RV style receptacle, the ground is the center prong, the neutral is the wide side blade, and the hot is the narrow side blade.
Sorry, I know what to do in a situation like this but it is hard to explain....
Old 03-19-2015, 03:15 AM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
A Young boy was killed by an Electrified Airstream last June in Amboy, Illinois. A non-contact voltage detector should be used to locate the short. The trailer/motorhome frame should be grounded, so you will not be killed. The short could be anywhere in the circuits, as well as any on board appliances. Start with an ohmmeter between hot and ground to localize the problem. To start, Unplug everything, including the Converter. Go through all the 110 volt breakers, one at a time, plus check the source wiring and the 110 input cord.
Skin electrified. Help? NJtoNC Electrical - Systems, Generators, Batteries & Solar 16 11-09-2014 07:10 AM
Exterior electrified, no joke! bonuts Batteries, Univolts, Converters & Inverters 20 10-06-2013 09:19 PM
Electrified '64 Globetrotter VTreeHokie Electrical - Systems, Generators, Batteries & Solar 9 08-26-2009 09:10 PM
Frame electrified ... BAD? OregonArgy Electrical - Systems, Generators, Batteries & Solar 13 04-13-2008 11:25 AM
325 MH tire size? TRAPEZE Tires 2 12-12-2002 09:31 AM
