Old 09-25-2009, 10:12 AM   #1
1989 34.5' Airstream 345
Saltillo , Mississippi
Electrical problems on '89 airstream 345
My owners manuel says there is a ac electrical fuse box in rear of mh. I can not find it anywhere does anyone have a idea where it may be? Also none of my outlets work on generator power, is this normal?
mater4 is offline   Reply With Quote
Old 09-25-2009, 10:47 AM   #2
345bill's Avatar
Las Vegas , Nevada
Keep in mind alot of item's located in one 345 isn't necessarily the same in someome else's 345. On my particular 1990 345LE the fuse/breaker box is located under the kitchen drawers, where my convertor is. I've read here on the forums of others speaking of a rear box, though.
Providing circuit breaker isn't tripped the 110V outlets are always hot when generator is running or when plugged in to shore power.
345bill is offline   Reply With Quote
Old 09-25-2009, 11:31 AM   #3
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
My LY has house circuit breaker box under bed, however it has a house 12v fuse box near doghouse behind drivers seat on floor. Having said that most problems I have had tracing wires is that you will find a fuse in line for a number of things far removed from it's electric source and sometimes far from it's component part. The generator has fuses at the generator. Inverter has a receptacle and fuse. Probably good idea to make a note when you find a fuse, maybe even try to discover what it is connected to, eventually all will be found.
Old 09-25-2009, 12:13 PM   #4
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
We have a breaker box in the overhead compartment, drivers side above the rear bed
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 09-25-2009, 12:28 PM   #5
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
The '86 'Silver Bullet's' breaker box in the back over head roll-up door cabinet over the rear bed on the passenger side, close to the middle.
mel
choctawmel is offline   Reply With Quote
Old 09-25-2009, 01:26 PM   #6
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
If they work on shorepower then it's not your breaker box, the relay from the generator is not transferring power. Does your air conditioner and inverter work from generator?
Old 09-25-2009, 03:14 PM   #7
Liberator
klattu's Avatar
1972 Argosy 24
Heart of Dixie , Alabama
Images: 834
My '89...behind a door at floor level near the kitchen sink.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 09-25-2009, 09:39 PM   #8
3 Dog Nite's Avatar
Cleveland , Tennessee
Hey mater4, your question intrigued me as I also have a 1989 345 LE. My manual on page H-66 shows the breaker box (Y-1) right next to the power cord reel & not under galley cabinets. My page H-67 states there is a 6 position rotary switch to select which appliance will receive the 110 volts AC. My MH has neither of these. Maybe AS didn't update all the diagrams with each new years' design.
If only 1 outlet didn't work I'd say check the breaker. If none work there might be a connection problem at the Energenius (univolt). I'm assuming the outlets work on shore power? Does the fridge work on genset & AC? How about the A/C units? If fridge & A/C's work, but not outlets, start looking for power with a tester at the breaker box. check before & after the breakers. PO might have rewired w/o outlets so they could use on 20amp circuit at home (guess). Also check for power at the automatic switchover relay box. It feeds 2 circuits. Maybe you have 1 bad contact there.
Posting these findings may help us diagnose the problem further.
Ricky
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Do you have problems getting WiFi in your Airstream? WiFiRanger Electronics & Connectivity 27 02-08-2012 01:01 AM
Big electrical problems in a 345 silverdream2 Classic Motorhomes 15 11-28-2011 06:14 PM
Where not to buy an airstream scorpiontimo Off Topic Forum 25 04-27-2011 05:09 AM
