Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 11-12-2014, 06:33 PM   #1
morlach's Avatar
DuoTherm Furnace
I have been updating some fittings and resealing them on my built in propane tank and have been running on an external 5-gallon tank. This morning I tried to use the furnaces. They seem to be functioning normally, other than the fact that they will not light. Is it possible that the external tank is not delivering enough pressure to activate the gas valve? I will be getting the main tank refilled pretty soon, but was curious as to what could be causing this. Thanks.
morlach is offline   Reply With Quote
Old 02-23-2016, 10:46 PM   #2
Mike1997's Avatar
1998 36' Land Yacht Widebody
Shepherdstown , West Virginia
Images: 14
This is a 2 year old post but thought I would add a comment.
My 1997 LY diesel came with electric heat in the roof units and a large furnace that also heats the holding tanks. The Airstream was used mostly in Florida and trips to the Carolina coast. After I bought it last April, I took a job transfer to Montana. On arrival the furnace would not operate longer than 10 seconds. Turned out the computer board was bad. Many plastic parts tend to deteriate after about 10 years. Tech was shocked when he looked at the furnace and discovered it had never been used.
Mike1997 is offline   Reply With Quote
DuoTherm furnace in '67 Globetrotter. Cflower Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-08-2014 10:47 PM
Duotherm Furnace replacement? EricktheSOB LP Gas, Piping, Tanks & Regulators 0 04-23-2012 09:31 AM
Can't get duotherm to acknowledge furnace... movin-in Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-19-2010 07:28 PM
need gasket for original DuoTherm furnace KHarris Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-01-2006 04:33 AM
345 DuoTherm model? pbnjsellers Furnaces, Heaters, Fireplaces & Air Conditioning 6 05-24-2005 10:41 AM
