Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 11-11-2007, 03:01 AM   #1
harold1946's Avatar
Profile:  Surprise , Arizona
Duo-therm heater
We purchased our first MH in July. 2005 Airstream LY 30' gas. We Plan to retire soon and do some traveling. Being avid campers for over forty years, we decided to try a mh. So far we are very pleased with our Airstream and look forward to hitting the road very soon.
Our ac units have the heating element option which I wanted to use to take the chill off but I must be doing something wrong. The ac unit is working fine but the heat elements wont come on. Wound up using the furnace.
harold1946 is offline   Reply With Quote
Old 11-11-2007, 08:07 AM   #2
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Hi Harold,
If you have a Dometic Comfort Control thermostat, it should be placed in the 'electric heat' setting to activate the heat strips in the air conditioner units. If you do not have this type of t/stat, then there should be a 'heat' position on the elector switch on the unit's faceplate. Remember that the heat strips don't put out much heat!
If nothing works, the heat strips might not be plugged in to the unit on the inside, or the dip switches might be in the wrong position. Either one of these requires opening the unit and getting inside. If you are still under warranty, (3 year from Dometic) you will void the warranty if you do this yourself.
Take it to a Dometic warranty repair center if you need this work done.....it should be free!
Lew Farber -Certified Master RV Tech (currently on Forums posting sabbatical, but lurking in the background )
WBCCI #1456 and about to resign!/VAC (assoc) #1456/ AIR # 10325
TAC# OR-1
CHARTER MEMBER: FOUR CORNERS UNIT
Old 11-12-2007, 02:38 PM   #3
harold1946's Avatar
works now
Thanks Lewster; works a lot better when I do it right. I just may learn all the systems yet. Have a great day!!!!
Old 11-12-2007, 04:18 PM   #4
lewster's Avatar
Glad you got it working!
TAC# OR-1
Old 11-12-2007, 05:08 PM   #5
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
......just one more HOT TIP from Lew :-)
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
Duo-Therm A/C on my Avion. 68 Suburban Furnaces, Heaters, Fireplaces & Air Conditioning 4 09-06-2009 11:20 AM
duo-therm not working toolman5252 Furnaces, Heaters, Fireplaces & Air Conditioning 6 02-03-2006 11:24 PM
Duo-Therm Penguin odor startrekker2001 Furnaces, Heaters, Fireplaces & Air Conditioning 3 07-22-2003 08:49 AM
Duo Therm Brisk Air JAG Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-06-2002 08:29 PM
Duo Therm Penguin A/C Installation JAG Furnaces, Heaters, Fireplaces & Air Conditioning 1 03-18-2002 10:11 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
