Old 08-06-2006, 10:10 AM   #1
1983 30' Airstream 300
Plantersville , Texas
Door hinge help
The top hinge on the door to our 83 MH appears to have the screw threads stripped out they won't tighten nor can we screw them out. Has anyone taken off a door to repair a hinge. Our door was hard to shut and dragging on the bottom latch side. We put nylon washers onder the hinge pins and that helped. can I take the panel loose on the interior wall behind the hinge and get to the area that the bolt screws into or should we try to get the screw out and regrove to the next larger screw. It appears that the door frame has been removed at some time as the rivets look like they have been smoothed with a dremil tool not the rivet shaver. We are not sure what to do to fix it.
Kay and Roy
carnegie1935 is offline   Reply With Quote
Old 08-06-2006, 02:22 PM   #2
Kay and Roy, if you type "door hinge" in the search box at the top of the screen you will get an avalanche of unwelcome news. Try clicking on this one, for example:
http://www.airforums.com/forum...oor+hinge+nick
The engineer was on vacation when this door hinge setscrew assembly was "designed".
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 08-07-2006, 01:07 PM   #3
Your answer was not what I wanted to hear, but what I expected.
I guess that we will attempt to repair soon. It is just too hot here in Texas to attempt for now.
Thanks Kay and Roy
Old 08-07-2006, 01:24 PM   #4
Courage, brother (and sister), do not stumble,
Though thy path be dark as night!
(It really doesn't take that long to fix)
Nick.
Old 08-07-2006, 03:09 PM   #5
Kay and Roy
Motor home entrance door hinges are available.
