Old 10-07-2011, 09:18 PM   #43
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Originally Posted by perryg114 View Post
I am going to try this route to making a new door handle. I have a machinist that I work with and he makes things for me on the side. If the cost is not too bad I may have several made. I already make motorcycle parts so why not Airstream parts. My handle broke once and was welded. I will make new ones out of 6061-T6 aluminum which should be much better than the Aluminum Zinc Casting the original was made out of.
Perry
This is an older thread. A forum member, John Burkey, has made some out of stainless steel and has them available. Here is a link to one of his posts about them. The following post has a photo of the one I got from him installed on my 1983 Excella. Very nice piece.
Vaughan
Old 10-08-2011, 07:57 PM   #44
1981 31' Excella II
New Market , Alabama
You got a link to his stuff or do I have to contact him directly. I can probably make one for free. You sure he still makes them?
Perry
Old 10-08-2011, 10:36 PM   #45
1983 34' Excella
1967 24' Tradewind
Images: 32
Perry
You can send him a personal message (PM) here on the forum. Some others have contacted him since I did, so as far as I know they are still available. If you look at the last post in the thread where I posted a photo, there is a "thanks" message from just a couple of months ago.
He is a member who did exactly what you discussed, had one made for himself and made them available to others. He's not a dealer or anything, so there is no website to link to.
If you do decide to make your own, there is a nice measured drawing in post 19 in this thread. Ajheinonen converted an autocad drawing to a pdf so he could post it here. He also posted a dxf version in post 27, but changed the file extension to txt so he could post it. You will have to change the extension to dxf to open in a CAD program.
Let us know what you do.
Vaughan
What makes an Excella an Excella? MaraLindstro 1990 - 1993 Excella 16 07-08-2012 11:05 PM
Exterior door lock replacement 1986 Excella kellywood Doors & Locks 3 07-25-2011 06:34 AM
Replacement LED fixture under front cap Pat Conway Lights - Interior & Exterior 2 04-12-2011 01:22 PM
Excella Info? M Williams 1981 - 1983 Excella 4 01-26-2011 07:13 PM
