Old 08-30-2007, 10:46 PM   #29
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
Originally Posted by guy99
If you find a shop to do it you might get a better price if you were ordering multiples. I'd certainly commit to one. Bet there are a good number of other's who need one.
Hi Guy,
We'll check and let you know what we find out. Ron
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 09-18-2007, 08:59 PM   #30
1978 28' Argosy 28
sarasota , Florida
my handle gave up the ghost as well, hand made a replacement from a plate of stainless steel with two triangle parts welded in place to strike the latch arm. also reinforced the tabs on the latch arm with a small weld inside the ninety degree bend. mine showed slight sings of fatique. with alittle polishing the replacement looks better than the original ever hoped two. total cost 10 bucks. had stainless plate laying around in the pack rat bin. and my wife question the pile of junk i hang on two !
roy sedgwick is offline   Reply With Quote
Old 09-19-2007, 07:10 AM   #31
str8strm's Avatar
any picctures?
sounds like a simple fix....so you have any pictures of the back side of it? before installation perhaps? thanks Debbie
AIR 7992
Old 09-19-2007, 07:34 AM   #32
87MH's Avatar
1978 31' Sovereign
Images: 292
I'm in for one!
The door handle on the 345 gave up the ghost last night - bbahor - broken beyond any hope of repair.
Anyone getting a handle manufactured to similar to ajheinonen's shown in the previous pix please let me know the anticipated cost - I am ready to commit.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 09-19-2007, 08:47 AM   #33
str8strm's Avatar
we are in also
Have not found a machine shop that is interested yet. please count us in for one if you can find someone to make them. I know guy 99 wants one also. Any machinist out there? Debbie
AIR 7992
Old 09-21-2007, 11:04 AM   #34
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
While the door handle may be the focus of this thread the real culpret in all of the door handle woes seems to be the sliding plate inside the door mechanism.
This is the plate with two "ears" or tabs on it that the handle actuates to pull back the latch.
That's the part I need, times 5...
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 09-21-2007, 11:45 AM   #35
We found several machinists in southern California that would make that part for the motorhome lock.
That's not the problem.
The problem is the cost. No one would want to buy them.
It is far cheaper to replace the entire lock assembly with one that has been available for years, and will continue to be down the road as well.
A small modification to the door is necessary.
There is an advantage of using a new style lock, and modifying the door.
Should the new lock or parts of it break, you simply replace the lock, which at that point would require about 5 minutes labor.
It's kind of like do you want to face the issue now, or later? The later choice obviously, would cost more than it would today.
That new style lock today costs about $120.00.
Having parts made commercially for the old lock, would far exceed that price, and you still would have an old lock.
Old 09-21-2007, 06:45 PM   #36
GlenCoombe's Avatar
Belleview , Florida
Images: 27
Andy, what modification to the door is required? As I've got five handles on the funeral coach I'm using them as required and would like the option of having all working as required.
Thanks.
Old 09-21-2007, 06:50 PM   #37
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Not much with the right tool
Andy, what modification to the door is required? ...
A little "tweaking":
Tom
Old 09-22-2007, 07:32 PM   #38
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Glen,
When my lock failed (due to the ears on the plate you mention), I had someone weld some tabs on the plate and then ground them down until they were the correct size to replace the ears. Took some time but wasn't that difficult just tedious.
I can see some stress cracks on the handle of the lock now and know that at some point, it will break and then my goose will be cooked.
I believe Andy's replacement requires a patch over the existing cutout (which is too large for the new lock) I don't think it would look very good on my rig which is painted.
Maybe one of us will find a good solution.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 09-23-2007, 08:53 AM   #39
str8strm's Avatar
Guy is right about the new door latch
we bought one and it will be the last resort, it is much smaller and when did a test fit the patch looked HORRIBLE and you have to do one on the inside as well. We will pursue working with the original lock before we go with the ugly ifx.
AIR 7992
Old 09-23-2007, 11:15 AM   #40
Thanks.
Part of the inner stiffner or stringer needs to be removed.
Our kits were designed to have some type of answer, instead of sorry, you have to do without.
Plating the door to some owners is ok, to others it is not.
Keeping things original, is fantastic, but there comes a time that other measures must be implemented, or simply, do without.
Having parts machined for the old locks, is a very good idea. The problem is to find a good machinist that will make some parts, at a reasonable price.
Those machinists, don't exist in southern California.
Old 09-23-2007, 12:24 PM   #41
guy99's Avatar
Images: 16
Andy,
I agree with your comments and very happy that you have a solution. That way I know I have a fall back I can trust if my other approaches don't work. We count on you.
Guy
Old 10-07-2011, 08:09 PM   #42
1981 31' Excella II
New Market , Alabama
I am going to try this route to making a new door handle. I have a machinist that I work with and he makes things for me on the side. If the cost is not too bad I may have several made. I already make motorcycle parts so why not Airstream parts. My handle broke once and was welded. I will make new ones out of 6061-T6 aluminum which should be much better than the Aluminum Zinc Casting the original was made out of.
Perry
What makes an Excella an Excella? MaraLindstro 1990 - 1993 Excella 16 07-08-2012 11:05 PM
Exterior door lock replacement 1986 Excella kellywood Doors & Locks 3 07-25-2011 06:34 AM
Replacement LED fixture under front cap Pat Conway Lights - Interior & Exterior 2 04-12-2011 01:22 PM
Excella Info? M Williams 1981 - 1983 Excella 4 01-26-2011 07:13 PM
