Old 03-11-2007, 12:15 AM   #15
Full-timer
nickglase's Avatar
1988 34.5' Airstream 345
new york , New York
Dick,
I know it's been a while since you posted this door handle post, but I'd love to see a photo of the custom door handle you had made. I've been having door woes and also hope to keep the original.
thanks, Nick
Urban camping in San Francisco, Ca
1988 Airstream 345 Motorhome
1964 Vespa GS
1982 VW Qauntum, turbo diesel
1979 Triumph Spitfire 1500
nickglase is offline   Reply With Quote
Old 04-11-2007, 01:00 AM   #16
Airstreamin' in Canada
Waterdown , Ontario
Originally Posted by nickglase
Dick,
thanks, Nick
same here.
Michael
mlang905 is offline   Reply With Quote
Old 05-08-2007, 05:48 AM   #17
1968 22' Safari
1982 28' Airstream 280
Gloucester , Massachusetts
Handle
I would like to get a copy of the drawing for the handle. My handle had the bottom tab broken off, I attempted to repair with Alumaloy (alum or pot metal solder) the tab started to melt, what a mess. I cut a replacement tab out of alum and pieced back together, a little misaligned any ugly but it opens the door. I also would like to see a picture of the New handle. My MH is a 1982 TurboDiesel 280.
ajheinonen is offline   Reply With Quote
Old 05-08-2007, 11:55 PM   #18
Chuckles's Avatar
Iwerne Minster , Dorset. UK
I am not sure if I am on the same track but my '82 build 310's door handle assembly is very slack and loos. I am sure a replacement will be needed very soon. Here in the UK parts are ..... shall we say ....Difficult? So I will certainly be interested in a replacement lock complete.
I have AutoCAD here so an emailed copy would be welcomed. There are a few (only a few) AS MH's here and I am sure they too will be needing something soon.
Chuck
Dorset UK
Don't take life so seriously.... it is not permanent!
Chuckles is offline   Reply With Quote
Old 06-07-2007, 05:53 AM   #19
1968 22' Safari
I got the autocad drawing from Dick. It won't attach as a dwg file, so I converted it to a pdf, it looks like what my old handle should look like.
Regards, ART
Old 06-07-2007, 06:29 AM   #20
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Can you post a picture of the finished product please.
Old 06-07-2007, 06:33 AM   #21
1968 22' Safari
I would like to see one also, If Dick doesn't post a picture of his, I will take a picture after I get one made. I'm thinking of having one made from a block of Aluminum.
Regards, ART
Old 07-09-2007, 01:20 PM   #22
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet .dwg Extension Workaround
Regards, ART
Hi Art,
Thanks for posting the pdf. You could change the .dwg file extension to .txt and post it with instructions to rename the file .dwg. I do that with .exe files that most email systems block now.
Vaughan
Old 07-21-2007, 09:33 PM   #23
1968 22' Safari
Here is a Nitetime photo of the handle I had made out of a block of aluminum.
it just has a finish done with a scotch brite pad, but it could easily be polished.
Old 08-30-2007, 03:22 PM   #24
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
sweet
WHo made it for you and what did it cost? We just got the new door handle assembly from airstream and it would look really bad if we install it as it is much smaller.
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 08-30-2007, 07:38 PM   #25
1968 22' Safari
I had mine made by friends in a machine shop as a favor, can't say what it cost if I hired a machine shop to do it.
Take the drawing I attached to a machine shop and get an estimate, I would guess it could be done for about $75.
Old 08-30-2007, 07:41 PM   #26
1968 22' Safari
I just want to note that the handle that you grab is what I had made, the rest of the door handle assy is original.
Old 08-30-2007, 07:53 PM   #27
1968 22' Safari
Here is the handle drawing I saved it as a dxf, renamed it to .txt.
After saving it, rename it as handle.dxf and any version of Autocad should be able to open it.
Old 08-30-2007, 09:01 PM   #28
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
If you find a shop to do it you might get a better price if you were ordering multiples. I'd certainly commit to one. Bet there are a good number of other's who need one.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
What makes an Excella an Excella? MaraLindstro 1990 - 1993 Excella 16 07-08-2012 11:05 PM
Exterior door lock replacement 1986 Excella kellywood Doors & Locks 3 07-25-2011 06:34 AM
Replacement LED fixture under front cap Pat Conway Lights - Interior & Exterior 2 04-12-2011 01:22 PM
Excella Info? M Williams 1981 - 1983 Excella 4 01-26-2011 07:13 PM
