07-13-2006, 07:59 AM
Does this Airstream have 23K or 123K miles on it?
07-13-2006, 08:04 AM
2005 28' Safari
Port Orchard
Looks like 23K, but the monocrhomatic underside with lots of rust, might it have been sitting in 3 feet of water at some time? The new carpet is hiding something.
07-13-2006, 08:10 AM
The tires are a tell-tale sign as well.
Your pictures make the inside tires of the rear axle look as though they have quite a bit of wear.
I am sure the original tires would not be good, no matter how much tread is on them.
Were the tires replaced with used tires? I know those tires are rather expensive.
I also agree with the rust thing. Although, you can park something like that over grass/dirt and wind up with the rust similar to that.
The driver's seat does not show much wear.
07-13-2006, 08:13 AM
2012 28' International
New Orleans
, Louisiana
I am leaning to 123K. Check the date code on the tires that may give you a clue. The pedal cover wear sure could be 23K.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
07-13-2006, 08:31 AM
1977 25' Caravanner
Jeffersonville
, Kentucky
Does it have any WBCCI #s on it ? or any other way of contacting the PO , owners manual or receipts any where in the coach,
Movie Stars and Film Crews come to Me from hundreds of miles enticed by My knowledge, My imagination,expertise, creativity and innovations!
07-13-2006, 08:33 AM
1977 25' Caravanner
Jeffersonville
, Kentucky
My fathers coach looked just like that one , it was parked around a low spot that collected water, it 40,000 miles on it .
07-13-2006, 08:34 AM
RivetAddict
1986 34.5' Airstream 345
Louisville
, Kentucky
I vote 123K....based on the tires and pedal cover. I think those seats have new covers - originals would give it away.
I've seen similar rust on south western units....almost a spotty rust. Mine was an east coast unit an had a more a consistant "patina" of rust on suspension parts etc.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
07-13-2006, 08:48 AM
1966 26' Overlander
Woodstock
, Georgia
I would agree with Steve, 123 seems more likely. Even 23 though if the thing was not used much, still could be the cause of many problems..sitting stored improperly is worse often than driving, and using.
If the price is right then mileage either way should not be too much concern. What about everything else? Interior , systems, floor, and so on.
07-13-2006, 12:01 PM
This is a picture of the brake pedal on my M-class with 123,000 miles.
Hmmmm.......
07-13-2006, 01:38 PM
New Orleans
, Louisiana
Hmmmm.......
Orginal or replacement cover? I dose not say Disc Brakes ?
Jim N5TJZ Air# 174
2011 F150 Ecoboost
07-13-2006, 01:43 PM
That shot is of my 1998 Mercedes ML-320 brake pedal, not the motorhome. It also has 123,000 miles. It is the original cover. I just posted it for comparison.
07-13-2006, 01:48 PM
New Orleans
, Louisiana
I will look at my F150 pedal covers when I leave from work. I bet the Mercedes cover wears better.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
07-13-2006, 01:59 PM
It's an American made Mercedes. IMHO, I think my Fords have held up better.
07-13-2006, 02:07 PM
Elgin
Better to have 123k on this MH for its age than 23k. It says "used" but not "overused". Being 30 years old with 23k is not a good combination, IMO
They put in new carpet apparently when they put in the new seats, too.
07-13-2006, 02:58 PM
Frank S
peoria
Hi Barry 2952--Tires and brake pedal say 123K to me. If tires are not originial, they would probably have about 10K miles for a 23K odometer. These tires look like a lot more.--Frank S
07-13-2006, 04:22 PM
Retired.
, At Large
Amount of grease caked up on the tie rod ends, tire wear, and oil seepage on engine indicate 123,000 to me, although it looks like 123,000 well-cared-for miles.
07-13-2006, 04:26 PM
1977 20' Argosy 20
Charleston
, West Virginia
1977 Airstream Excella 240? No such thing. Airstream did make a 24' Excella in 1979. All of the 1977 motorhomes were Argosy units.
07-15-2006, 08:10 AM
You are correct, it is a '79.
