Originally Posted by alfalsetto
....The kill cable was pulled more then one time to much, to hard. The last time was Me. I just forgot and full to hard.
Alfalsetto:
I know you have an '82 diesel, but I am somewhat confused by your reference to "Pulled the kill cable".....
Correct me if I am wrong, but I thought the "kill" cable was installed only for emergencies......the "ignition" key normally cuts off the fuel to the engine and stops the engine from running when the key is turned to the "off" position (as in a gasoline engine).
All of the "Pull to kill" (emergency) shut-offs on diesel engines I am familiar with work by shutting off the air to the engine rather than shutting off the fuel supply. Of course, Airstream (or a PO modification) could well have substituted an a manual pull-to-kill-the-fuel if the "electric" ("ignition" key operated) solenoid diesel kill (shut off) failed as an "easy" fix.
My point is, IF the dash mounted "Pull to Kill" switch actually DOES kill the engine by throwing a dam to the air inlet (thereby cutting off the air to the cylinders), there is a very real danger that, with continued shut down in this manner, you will damage various oil seals due to a continued "vacuum" being applied to the "air inlet" side of the diesel which, of course, was not designed to run with a vacuum in this area.
All of my actual experience with damage to diesels caused by continued use of the "Emergency Shut Down" (oil seal damage and eventually engine oil being pulled into the air inlet) has been with the Detroit Diesel 53-71-92 series engines. If this type of damage would not, or could not, carry over into your engine, my apologies in advance.
I know this thread is getting quite a bit off of the original question posed by Chaplain Kent (Dinettes), and if further questions (or a refute to my experiences with the 53-71-92 Detroits) maybe
ALANSD could create a separate thread in an appropriate location.
