Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 06-27-2005, 07:47 AM   #15
Chaplain Kent
Chaplain Kent's Avatar
Profile:  Wauwatosa , Wisconsin
My 82 deisel uses a pull kill to stop the engine, it is mounted on the dash. My new engine which is also an Isuzu engine uses this same pull kill to stop the engine. I questioned the mechanic and was told it is the design of the engine. The ignition switch does not turn off the engine, in fact it is just a starter switch. This was the problem when I tried to install a buzzer for my headlights. These deisel models have no ignition on off switch.
Chaplain Kent
1982 280 Turbo Diesel Motor Home (Chummy)
http://www.fuzzytravel.com/grandakent/
Chaplain Kent is offline   Reply With Quote
Old 06-27-2005, 08:53 AM   #16
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 143
Originally Posted by Chaplain Kent
My 82 deisel uses a pull kill to stop the engine, ....These deisel models have no ignition on off switch.
Thanks for the info....
Dennis
WBCCI # 1113
AirForums #1737
Old 06-27-2005, 09:37 AM   #17
alfalsetto
alfalsetto's Avatar
Profile:
I'm going to try and make some thing to stop the engine. It's not going to a kill cable. "I hope"
alfalsetto is offline   Reply With Quote
Old 06-27-2005, 10:10 AM   #18
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
soon to be , on the move again
Images: 58
I once drove a Kenworth with a Caterpillar engine that used the ignition switch to turn off the engine, instead of a pull lever. You turned the ignition "off" then turned it back to the "acc" position until the engine stopped. I think it was a solenoid that was normally open, and power closed it.
Also, some diesel engines have a compression release lever that will also kill the engine, this may be what the Isuzu has, it would be a lot easier on the engine if that is how it stops it.
Change is inevitable, except from a vending machine
AIR#2611
overlander63 is online now   Reply With Quote
Old 06-29-2005, 08:30 PM   #19
alfalsetto
alfalsetto's Avatar
Profile:
Isuzu has to have some thing to kill the engine beside the kill cable. I'm going to start to call around and see if I can find out some thing on it after the 4th. "I'm going camping for a week or so?" If not back to make some thing work!!
Old 07-04-2005, 08:52 PM   #20
swebster
RivetAddict
swebster's Avatar
Profile:  Louisville , Kentucky
Chaplain Kent,
I just finished building a new dinette for my 345. It's a drivers side unit set behind the couch. It has cutouts for the generator box and water heater.
You're welcome to the original setup less the cushions (4" foam) and some of the mounting angle aluminum. You can also have the table itself less the hardware.
Honestly, if your woodworking skills are there it's not too hard to build one from scratch using 1 x 4 stock and 1/2" plywood. I can also send you some pics of my old dinette and the new one if you think it would help sort it all out.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
View My ThisOldRV.com Personal Page
ThisOldRV.com
swebster is offline   Reply With Quote
Old 07-10-2005, 07:01 PM   #21
Chaplain Kent
"You're welcome to the original setup less the cushions (4" foam) and some of the mounting angle aluminum. You can also have the table itself less the hardware."
Thanks for the offer but I already have it done. I eliminated the dinnette and put in another sofa/bed. Actually I used an old gaucho. See the post under remodeling is 95% complete.
We now have a trestle table which stands in the middle aisle.
Chaplain Kent
WANTED: Front Dinette Photos InsideOut General Interior Topics 21 01-12-2007 03:09 PM
Seeking plans for dinette FrankR General Interior Topics 24 05-01-2006 01:27 AM
dinette chair storage bjstewart1 General Interior Topics 16 03-24-2005 09:37 AM
2003 International AS Pahaska 2003 International 147 05-28-2004 09:48 AM
Dinette - would like to add Diesel Dude Cabinets, Counter Tops & Furnishings 2 08-07-2002 05:08 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
