Old 10-20-2009, 11:15 PM   #15
1996 30' Land Yacht
tucson , Arizona
silly question.....same bulb??? never really looked inside of a taillight?? front parking lights on same circuit as well???
buckeyechad is offline   Reply With Quote
Old 10-20-2009, 11:45 PM   #16
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
The bulb will have two filaments, and two connections at the base. One for tail lights, the other for brake lights. It grounds around the perimeter of the base. The socket will have two connectors. That is another place to look for a short. The insulation on the wires where they go through the base of the socket may have gone bad. That will cause a direct short. If the short is at the light socket, usually the wire will burn at or near that point, but not always.
Lots of places to look for shorts to ground. But if the fuse does not burn when the running/tail light wire is removed from the switch, the short is somewhere along that wire. With the unit being fairly old, I might start by looking at the wires where they go through the sockets. Age coupled with vibration can cause the insulation to flake off the wires. I replace the sockets or at least the wire and socket base on lights on older cars during restoration. With age, the spring beneath the bulb connector and the socket base goes bad as well.
I will be interested to hear what you find.
Old 10-21-2009, 04:35 AM   #17
richinny's Avatar
2011 34' Classic
if you have a tow receiver on the back you should also check the wiring there.
can you post a picture of a few of the blown fuses. how the fuse melts can indicate the type of overload.
Ricky
Old 10-21-2009, 10:03 PM   #18
1996 30' Land Yacht
tucson , Arizona
i found it!!! after taking apart all the rear taillights, clearance lights, license plate frame light, tow hitch...and finding nothing. the first parking light in front i inspected was the culprit. somehow the two wires had melted together. i separated them...tied it off and turned on the headlight switch....and no blown fuse!!! will buy new part tomorrow!!!
thx for all the advice!!
Old 10-21-2009, 10:06 PM   #19
richinny's Avatar
2011 34' Classic
Ricky
Old 10-21-2009, 10:39 PM   #20
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, we always like a happy ending. And we really appreciate getting a final report.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 10-22-2009, 06:26 AM   #21
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Hooray!!!
power jack keeps blowing fuse? jlemmons Jacks, Stabilizers, Lifting and Leveling 6 08-01-2009 10:38 AM
Fuse blowing and sparking! Lily&Me Batteries, Univolts, Converters & Inverters 7 07-27-2009 01:18 PM
Fuse #1 keeps blowing Z33 Electrical - Systems, Generators, Batteries & Solar 12 12-16-2006 08:43 AM
Parking light fuse blowing andyfuson Tow Vehicles 7 07-26-2006 05:54 PM
Brake Light fuse keeps blowing BW_LandYacht36MH Land Yacht/Legacy Motorhomes 3 08-25-2005 12:25 PM
