Old 07-06-2012, 05:50 PM   #1
Airstream Driver Emeritus
PeterH-Airstreamer's Avatar
1993 34' Limited
Images: 59
Curved ceiling panels in Bath and shower
Has anyone ever removed the curved ceiling panels in the center shower/bath in the 345? Are they aluminum and can they be removed without taking the front axle out ? The vinyl is starting to show a lot of wear, would love to update it.
1993 34' Classic Airstream Limited TT
WBCCI# 5580 Member at Large
Air#13
Past Projects: 1979 28' Classic Motorhome, 1987 34.5 Classic Motorhome
PeterH-Airstreamer is offline   Reply With Quote
Old 07-13-2012, 07:08 PM   #2
1993 34' Limited
Images: 59
In the commode room, the vinyl is laminated to wood on the walls and to aluminum on the ceiling. I removed all the vinyl on the walls and now I am in the process of applying acrylic venetian plaster. The acrylic Plaster does flex and will not crack if applied over properly prepared surfaces. Eventually, I will just apply a sheet of exterior Aluminum to the ceiling, once I get a big enough piece.
Air#13
Old 07-14-2012, 05:44 PM   #3
1993 34' Limited
Images: 59
Just a little Plaster made a huge difference and getting rid of that old vinyl did change the smell that is so typical with the vinyl and the adhesive.
ID:	163132   Click image for larger version
Air#13
Old 07-14-2012, 07:01 PM   #4
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Looking good Peter!
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
