Old 01-11-2004, 03:49 PM   #1
cockpit windows
I have been waiting for the day when I break either the drivers side or passenger side window trying to slide it open! I am sure that this will happen in front of my wife (isn't that the way it works?) Anyway I am sure that I am not the only one with this problem. Any thing to save me from an embarrasing moment?
chiropup
chiropup is offline   Reply With Quote
Old 01-11-2004, 03:53 PM   #2
You have to take it out and clean the U channel. Incredible how fast and how much crud accumulates.
Dick
Navigator is offline   Reply With Quote
Old 01-11-2004, 04:19 PM   #3
87MH's Avatar
1978 31' Sovereign
Images: 292
Replace the Channel Liner
New Liner for the U channel is available, Sometime a slight "up" pressure on the latch helps on mine. A bit of lubrication may help, WD-40 or similar. (I really didn't say that, EVERYONE knows WD-40 is not a lubricant.)
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 01-16-2004, 08:25 PM   #4
silver buffalo's Avatar
Floyds Knobs , Indiana
"You have to take it out and clean the U channel."
The windows in my 310 are worse than sticking, neither one will move. How do you go about taking them out?
Rick Hill
83' 310
AIR # 2905
silver buffalo is offline   Reply With Quote
Old 01-17-2004, 08:50 AM   #5
Astrodokk's Avatar
1992 30' Airstream 30
Santa Rosa , Northern California wine country
I've had trouble with mine too. The previous owner replaced the channel, but the windows still didn't slide well. I used a silicone spray and it seems to slide easier now. However, currently the latch itself sticks and won't unlock unless I pull it away from the window a little. I sure wouldn't mind power windows in my next motorhome!
Astrodokk is offline   Reply With Quote
Old 01-17-2004, 08:43 PM   #6
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
i need a lock for the drivers side. i bought two a couple years ago at jackson center and they now dont work , i cant get them to open.
the windows slide for a while if you spray the channel with silicone lube, and then the start sticking after a couple weeks.
the fuzzy channel needs replacing also.
be nice if someone did a detailed brief on how to and the doos and donts. dont break the glass as none is available except junk yards. a friend had his broke and it took a year to find a replacement.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
wb13798 is offline   Reply With Quote
Old 01-18-2004, 07:50 PM   #7
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
From memory I don't think the slide portion can be removed
I re-U channeled my Drivers side 3-4 months ago. This is how I did it.
With the window closed, pull the U channel from the front lower corner until I got to the sliding window. Cut the old channel off. CAREFULLY slide the window into the slot you just emptied. Pull the remaining U channel off back up to the back edge of the now open window. Cut this off too. CAREFULLY slide the window back toward the closed position. Remove the top front section of U Channel. I cut a section that was longer than the piece I just removed. This is going to create a seam, I planned it to be at the middle of the top of the sliding portion when closed. Slide the end over the top of the closed window until you can get the other end inserted into the track.
Slide the window into the open position again. Then using a section longer than necessary slip the new U channel under the bottom of the window from back to front. The U channel will fit, but you will have to work it some. You may have to lay the U channel in the groove part way back and slide the window glass on it, then pull it through with a pair of needle nose pliers, or work it using the sliding back and forth of the glass. Your goal is to have a single piece from lower front up to the seam at the top.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 01-19-2004, 10:26 AM   #8
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Here is a link to info on the use of a rubber repacement channel that Peter bought from his local glass guys.Window channel
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
