Old 11-16-2007, 02:32 PM   #1
1986 34.5' Airstream 345
Tyler , Texas
Cockpit headliner
Hi! Another eyesore on the interior of my 345 is the headliner over the cockpit area....it has several cracks which have been stopped by a small drill hole but I would like to do something to repair them...I need some how-to on a cosmetic fix since replacement of the vinyl headliner may be too much even if a replacement is available. I also need to get rid of the mauve upholstery(how did women think this was attractive) which is a real eyesore but that is a project for another day.
Pete
pjude is offline   Reply With Quote
Old 11-16-2007, 07:34 PM   #2
buckwheat's Avatar
1987 34.5' Airstream 345
Hendersonville , North Carolina
I've not seen a solution to your question in the forums but I have the same problem in our '87 345, both fore and aft ceilings. A possible solution may be to treat it like a vinyl siding repair... seal the holes and cracks with plastic epoxy, then paint the entire area with two coats of 100% acrylic latex paint.
BubbleHead Fred
"Underway is the only way!"
buckwheat is offline   Reply With Quote
Old 11-16-2007, 08:41 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Pete,
Go to your local, well-stocked auto store and buy a good vinyl repair kit. You can custom mix the required color, and they give you a set of texture sheets to match the 'grain' of the vinyl. The really good sets even have a heat iron to speed the cure.
I've used them and with a little practice, you can match the look and feel of the liner and make the cracks go away!
Old 03-14-2008, 06:06 PM   #4
1997 25' Safari
PALM SPRINGS , California
hanging headliner
Suggestions On How To Re Attach Sagging Headliner?
alscottfree is offline   Reply With Quote
Old 03-15-2008, 06:17 PM   #5
lewster's Avatar
3-M Super 90 spray adhesive. The stuff is bomb-proof..............just follow the directions!
cockpit heat ALANSD Mechanics Corner - Engines, Transmission & More... 15 04-25-2012 02:28 PM
cockpit windows fuzzy channel replacement wb13798 General Motorhome Topics 33 01-10-2010 09:49 AM
headliner glue bikestreamer Upholstery, Blinds, Walls & Interior Finishes 2 11-17-2006 07:12 PM
cockpit windows chiropup General Motorhome Topics 7 01-19-2004 10:26 AM
Headliner CBBOB Upholstery, Blinds, Walls & Interior Finishes 3 09-02-2002 06:53 PM
