Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 08-11-2003, 06:01 AM   #1
ZenRVer
ZenRVer's Avatar
Profile:
Cheapest New Generator (Onan)
www.Colorado Standby.com offer the least expensive generator delivered to your door.
I have had two 2800 Microlite Gensets break on me. Both had bad rotors. On the second one I had a new PC Board and starter replaced before the rotor went........(HUGE wasted $$$$$!!!!)
In short, rotors are faulty, and there is a design flaw between Onan and Airstream in the B Van.......too much draw and not enough power if you are a fulltimer and like to use your AC unit. There appear to be no options for other generators to fit into that small compartment.
Since I can't do all that engine repair work that others have mentioned in this forum - I'm not a happy camper!
Home, home on the roam!
ZenRVer is offline   Reply With Quote
Old 08-11-2003, 06:29 AM   #2
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Zen, Honda makes a built in RV genset. Not sure what the model number is, but I bet it cost less than two Onans
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 08-11-2003, 08:37 AM   #3
wb13798
wb13798's Avatar
Profile:  2004 28' Classic
huntsville , Alabama
bet it wont fit in the hole the 2.8 is a small gen set. to bad you cant fit a 4.0 in the hole that is a great set for one ac plus.
al
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB
wb13798 is offline   Reply With Quote
Cheapest place to find entry door handles??? tin can luv Doors & Locks 0 02-02-2004 11:20 AM
