Old 11-15-2013, 09:13 PM   #1
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Center Caps
Anyone out there know what size center caps to use on the P-30 Chevy Chassis? I've tried measuring and still order the wrong size.
Any help would be appreciated.
Thanks, Derek
Old 11-16-2013, 09:27 AM   #2
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
When I get back home I can measure mine if you like.
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 11-16-2013, 09:54 AM   #3
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
I'm assuming that you're talking about the Alcoa aluminum wheels. Correct?
Front or rear caps?
I couldn't find one that was the correct diameter for my front so I bought one on ebay and enlarged the trim ring to accomedate it. Ended up opening up the hole about 1/8" all around. Other then it saying Alcoa instead of Airstream, you couldn't tell. I still have one on the road side that is OEM. The rears and TAGs are all OEM as well.
How are you taking the measurements? I measure across the bottom flange, and then the height. The problem I've found is that some have a wider flange then others and that throws the measurement off. I do have some calipers I can use to measure before the base of the flange that goes through the hole in the trim ring.
92landyacht is offline   Reply With Quote
Old 11-16-2013, 11:43 PM   #4
crazeevw's Avatar
Sorry, I should've specified. Looking for rear caps. Believe Raveson has PM'd me with a contact.
Has anyone found the chrome acorn lug caps?
Thanks, Derek
Old 11-17-2013, 11:03 AM   #5
Rivet Loser
Punch's Avatar
La Ronge , Saskatchewan
Thanks, Derek
Are these the right size?
60 Stainless Steel Lug Nut Covers for 1 1 2" Truck Trailer Lug Nuts | eBay
or these?
40 New Chrome Lug Nut Covers Caps for 1 1 2 Size Lugs RV camper Winabago Bus | eBay
Punch is offline   Reply With Quote
