Old 02-21-2005, 08:23 PM   #29
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
It works! Do you think you will need two irons (and two sets of hands) for the longer finish piece? Hmmm, I don't remember a "birch" setting on my iron though
Marc
Old 02-21-2005, 08:43 PM   #30
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Marc - good question. Seemed to remain fairly workable for me. In fact I may have even "over steamed" it. I think this locker is managable by one, but the longer lockers on the driver's side will require some buddy power for sure.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 02-21-2005, 09:21 PM   #31
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Did you use the iron's steam, or did you wet the towels?
Uwe
www.area63productions.com
Old 02-22-2005, 05:36 AM   #32
RivetAddict
swebster's Avatar
Uwe - just the steam from the iron. I left the towel (actually two washcloths) dry.
Steven Webster
AIR 1760
Old 02-27-2005, 06:23 PM   #33
RivetAddict
swebster's Avatar
Update - Sort of
I wanted to report back on my progress over the last week but there wasn't any. It certainly wasn't for lack of trying. Over the last week I tried three different methods of bending the birch over the frame.
First I tried 1/4" finish birch cut to size using the steam iron. It did not take long at all to realize that the iron that easily bent a 12" test peice just didn't put out enough heat and steam when you upsized it to 67". So the search began for another steam source. After looking at steam cleaners and other ideas I saw a Wagner wallpaper steamer on an end cap at the local HD. $49 later and I had all the steam I needed!
So back to bending; sort of. After steaming the 1/4" birch for about a hour the bending was not going well. The outer plywood was showing some seperation in the grain around the radius and I got some severe warping inbetween the frame ribs. It ultimately made the bend but it looked terrible - kind of wavy.
Next I tried adding some 1/8" kerf cuts to the back of the plywood to try and relieve the stress on the front to eliminate the warping the the opening of the grain. Well about ten minutes into the bend the piece just broke into two pieces. Clearly they aren't joking that the strength of plywood is in the sandwich concept.
So I called around for 1/8" bending plywood and after talking to the wood store guy on the phone it seemed like this bending ply had the opposite properties of regular ply...very flexible and would need a laminate or veneer applied to keep it's shape. Since we thought about laminating if the exposed birch didn't work I was thinking this would be the way to go but they could not get a piece large enough until Monday.
Not being one to sit the weekend out I started experimenting with some other materials I already had around the shop.
First I tried some 1/4" hardboard (like pegboard but without the holes). This bent easily around the frame after about ten minutes of steaming and held it's shape after drying. Hmmm...certainly cheaper than bending ply and with some laminate applied over it who would know. The only downside was that it was really heavy and adding the laminate and 1/4" plexiglass doors would make for some very heavy roof lockers.
So I kinf of thought the 1/8" bending ply with laminate was the plan. That is until until I was playing PS2 with my son in the playroom and looked up at the wall. There hung a 4' x 8' x 1/8" piece of Malonite I had hung as white board for the kids to draw on. This is the stuff in the paneling ailse at HD for about ten bucks and is typically used for paneling bathroom walls.
Five minutes later I had it off the wall and was cutting it to size. It had a lot of potential - 1/8" hardboard so it would bend easily and already coated in a white moisture resistant facing so no laminating or finishing would be required. Plus its cheap and as my wife pointed out - the kids could write on it with dry erase markers on those long trips.
Anyway the test piece bend up well, looks great and other than cutting out the door opening and sealing the endcaps - it pretty much done.
Hope ya'll don't mind the long update but since a few of you out there may be interested in building similar cabinets I felt like the more info the better.
Here's some pics....
ID:	10644   Click image for larger version
Steven Webster
AIR 1760
Old 11-28-2005, 12:07 PM   #34
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Any newer updates on this project? Just curious.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 12-02-2005, 09:01 AM   #35
RivetAddict
swebster's Avatar
Alan,
After working on getting the "CCD" look for a while and not having much success bending plywood I ended up going in a different direction. I'm re-using the original cabinet frames, but have stained them dark ebony. I'm also adding frosted sliding doors instead of the raised panel doors.
Interestingly, they look like a darker version of the overhead lockers in the 75th aniversary edition.
Pics here (at bottom)
Steven Webster
AIR 1760
Old 12-02-2005, 11:40 AM   #36
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I missed those when you posted them, really looking good in there. It is coming together well.
AIR #005
retired!
2003 International CCD Pahaska 2002 - 2005 International 5 10-27-2006 10:37 PM
CCD 2nd excursion ChrisAich 2002 - 2005 International 18 07-29-2003 04:34 PM
310 Overhead cabinets jkleven Airstream Motorhome Forums 7 07-23-2002 12:08 PM
The CCD vs the AS Pahaska Our Community 2 06-11-2002 03:47 PM
Re-attaching cabinets to the interior skin. Andy R Cabinets, Counter Tops & Furnishings 5 04-07-2002 02:54 PM
