Old 04-11-2007, 01:18 PM   #1
tn2
DixieDove
tn2's Avatar
1978 Argosy 27
1978 28' Argosy 28
Camden , Tennessee
Cargo Compartment Lights
Can anyone enlighten me on how the cargo compartment lights are wired up. I guess the correct name for these compartments is Trunk Lights. I have a switch on the dash that when switched on a green light comes on at the switch but none of the lights work. I've checked a few of the bulbs and they are good. I take it that these lights are wired in series....one switch operates all lights. Does anyone have a wiring diagram of these lights on a 78 Argosy 28ft motorhome.
Thanks much
Charles
tn2... Bad thing about doing nothing is you never know when you're done.
tn2 is offline   Reply With Quote
Old 04-11-2007, 02:48 PM   #2
bobchevy89's Avatar
1977 24' Argosy 24
Inverness , Florida
Exclamation back track
I had the same problem, I started at the switch wit a probe light went down the wire till I found where there was no powerlooked back to where power was last put in a jumper wire and had power found 2 more broken spots putting in jumper wire helped till I can replace the whole wire.
just want to camp happy
bobchevy89 is offline   Reply With Quote
Old 04-11-2007, 04:03 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
The lights will be wired in parallal with each light tapping off the wire as it goes throughout the rig. This may look like a series circuit but it not, each light has it's own power source off the wire and it's own
path to ground. As noted above if all the compartments are out the brake in the wire will be between the switch and the first compartment.
If you find an open in the wire and install ajumper make sure you cut the original wire at each place you install the jumper. If you just clip on to the original wire and the wire is broken somewhere in the chassis it could short at the brake and cause other problems.
The fact that all the lights are out looks like a wire problem but make sure the sockets are not just corroded. Test the first one to a good ground with a good pointed test point.
2004 Excursion 4x4
Old 04-11-2007, 05:26 PM   #4
tn2
DixieDove
tn2's Avatar
1978 Argosy 27
1978 28' Argosy 28
Camden , Tennessee
trunk lites
I would assume that the "first" lite in the string would be in the compartment that is located front left. Thanks for the help.
Charles
Old 04-13-2007, 07:30 PM   #5
tn2
DixieDove
tn2's Avatar
1978 Argosy 27
1978 28' Argosy 28
Camden , Tennessee
Truck lights
I think I found the problem at the switch behind the dash. Found a wire pulled out of a switch...not really sure yet that it goes to the trunk lights....did not have time to hook it up....started to rain and I had to get some things out of the rain so I will hook it up tomorrow. I did look at several of the light assemblies and they are in poor shape.....probably will end up replacing them all with new. Thanks to all for your input...
starting to rain again....got to get the coffee and set on front porch....Favorite passtime....LOL
Charles
Old 04-14-2007, 05:04 AM   #6
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Lightbulb
I have the same switches, one day I'll look at what the heck is what...
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 04-14-2007, 06:52 AM   #7
tn2
DixieDove
tn2's Avatar
1978 Argosy 27
1978 28' Argosy 28
Camden , Tennessee
Dash
I don't have a switch for Aux Lights....what exactly is Aux Lights? I do have a hole and the label is there but there are no wires behind the dash for Aux Lights. Seems to me ...when I first took my dash out... there was a switch in that hole but I don't think it was wired up
Old 04-14-2007, 07:10 AM   #8
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
My Aux lights are Fog lights mounted on the front bumper. I think that I have a short in the wiring for them, If I flip the switch, the fuse blows...
www.balrgn.com
Old 04-14-2007, 04:50 PM   #9
tn2
DixieDove
tn2's Avatar
1978 Argosy 27
1978 28' Argosy 28
Camden , Tennessee
Lights
Oh...that explains that....I don't have fog lights
Old 04-14-2007, 05:08 PM   #10
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Me either till I find the short
www.balrgn.com
Old 04-15-2007, 08:50 PM   #11
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Images: 37
Took them off. (fog lights) Now the switch controls my transmission cooler fan, until I put a thermo switch for it! Also did not connect the indicator light. Way to bright driving at night!
Chris & Brenda, Members of the Christian Motorcyclists Association
AIR Member 12654
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (263,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 04-16-2007, 08:01 AM   #12
tn2
DixieDove
tn2's Avatar
1978 Argosy 27
1978 28' Argosy 28
Camden , Tennessee
lights
The loose wire fixed the lights....however....most of the light assemblies are so corroded that it took some giggling and rotating of each bulb to get them to light....so I will be replacing them all. I have a project on the to do list of cleaning and painting all the compartments so I will change the lights at that time also. Anyone know a good source for these lights.
Charles
Old 04-16-2007, 08:45 AM   #13
cmadmaxman's Avatar
Images: 37
Here are some ideas in LED's Charles.
Super Bright LEDs
I will be upgrading mine to LED's soon. They cost a little more, but if left on, low battery drain.
Peterson Mfg. makes a nice fixture for the standard bulb, and has a push button switch on the unit as well. I have used them before and they work well and put out good light.
Here is a link: Peterson Manufacturing Company
You should be able to get these at Walmart, NAPA or such. I took off the Micky Mouse bracket AS had, and mounted this directly to cabinet wall.
AIR Member 12654
1982 310 MoHo
Old 04-17-2007, 07:01 AM   #14
tn2
DixieDove
tn2's Avatar
1978 Argosy 27
1978 28' Argosy 28
Camden , Tennessee
lights
Thanks for that webb site....I'm sure they will have a light assembly that will work.
Charles
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
replacing compartment locks Dave Cole Exterior Storage Compartments & Access Doors 3 08-14-2008 07:34 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 09:09 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
Blinking Galley Lights ViewRVs Mechanics Corner - Engines, Transmission & More... 7 06-23-2002 08:42 PM
