Old 07-10-2015, 07:46 PM   #1
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
can this spring be welded
found my main awning spring to be broken. Can it be welded?
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 07-10-2015, 07:50 PM   #2
1978 Argosy 24
MooreHaven , Florida
Generally speaking springs should not be welded,as the heat can take the temper out of the metal in the area of the weld.
This is only temporary unless it works! Red Green
oldiesel is offline   Reply With Quote
Old 07-10-2015, 07:55 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Technically, yes, but practically, no. Most of what makes a spring a spring is the composition of the steel, the hardness it is hardened to, and the temper that it is drawn back to. The act of welding is going to wreck the hardening and temper in the area of the weld.
Does it hurt to try? Probably not--what the heck it might last another 20 years and work (almost) as intended.
Old 07-10-2015, 07:55 PM   #4
1981 31' Excella II
New Market , Alabama
No it can't be welded and it would crack again somewhere else. Get a new one from the awning manufacture.
Perry
Old 07-10-2015, 07:57 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
You can weld it, but it will never work correctly afterward. The heat will take the "spring" out. Then it will not be very long till it breaks again when it flexes.
Alan
Old 07-10-2015, 08:18 PM   #6
Huh?
Ultradog's Avatar
1975 27' Overlander
Twin Cities , Minnesota
Images: 8
You can not weld a spring.
I am a good welder and wouldn't even bother trying to weld that.
Ultradog is offline   Reply With Quote
Old 07-10-2015, 08:32 PM   #7
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Good metal prep, at least one full overlap wrap, lowest heat / amps for good penetration, file down the rough spots, and give it a try. It can be done. Let us know....
You cant weld suspension springs, leaf or coil, extension or compression. But a low tension torsion spring can.
NavyCorpsman is offline   Reply With Quote
Old 07-10-2015, 09:49 PM   #8
1988 Argosy 32
Lomita , California
Is that from the sun shade roller ?. git a new one if you can.
Wolfe is offline   Reply With Quote
Old 07-11-2015, 02:07 AM   #9
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I imagine that spring would be so apt to "blowing out" that it would look like a sparkler when the arc is struck,,, and even if a weld could be made it would be brittle beyond belief in the heat affected zone...
And besides, if the spring broke in one spot, even if by some miracle it is effectively welded, it will break somewhere else in short order.
Old 07-11-2015, 04:46 AM   #10
Airstream Driver
1997 30' Excella
Images: 51
Thanks everyone for the replies and expertise!
Its a Zip Dee awning and the springs are readily available
http://www.awningsbyzipdee.com/media...36ffffd502.pdf
1996 Airstream B190
AIR #13
Can aluminum skin be welded? Teched Ribs, Skins & Rivets 19 10-08-2013 09:48 PM
Original tongue jack...welded on, or not? adamperine General Repair Forum 6 08-18-2012 11:14 AM
Original Bambi Axle welded? C Ray Axles 12 02-29-2008 04:11 AM
Is my old jack welded on? Towster Jacks, Stabilizers, Lifting and Leveling 8 01-23-2008 05:31 PM
