Old 07-18-2010, 09:27 PM   #1
Exeter , California
BMW R1200 GS on the back?
Will the frame of an airstream say a 27-28 footer take the weight of a MC on the back bumper? Thanks
big-boss is offline   Reply With Quote
Old 07-18-2010, 09:38 PM   #2
_
so u wanna hang a 500LB bike on the back?
sure the frame will take that weight...
add 2 or 3 bikes, no problem.
just make sure the trailer frame is laying on the ground.
IF the stream is already built, take the tires off so it's planted...
________
r u serious?
________
and the H2 will be OVER the payload/towing capacity with a new 27 ftr AND the motobike...
cheers
2air'
Old 07-18-2010, 10:03 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Well u can always UPgrade to a 'wing and tow the 'stream and the H2 with that.
Old 07-18-2010, 10:30 PM   #4
_
ok we've had our fun at your expense...
u might want one of these...
http://www.airforums.com/forums/f503...ler-37974.html
but the h2 is not enough mule for that...
350 dually...
bike IN truck or bike IN pan-am...
both work.
more on the topic...
http://www.airforums.com/forums/f238...eam-44565.html
(don't be confused, the pic with a VESPA on back is a MOHO, not a traylet'...
cheers
2air'
Old 07-19-2010, 11:58 AM   #5
Exeter , California
You guys are too funny: But you told me what I needed to know. THanks alot it will keep me going.
I bought a coleman E2 tent trailer which has worked great the 5 times I used it but it is such a pain in the butt to load, unload and just stop and make a cup. So I want a trailer now- and the airstream is the top of the line but I want to take my GS with me.
Old 07-19-2010, 12:32 PM   #6
1999 25' Safari
Fairburn , Georgia
I carry my R1200GS in the bed of the truck while towing the Airstream. The tail gate has to stay home because it won't shut when a bike is in the bed, and it will hit the trailer in turns if it's down. Good luck.
JackMac is offline   Reply With Quote
Old 07-23-2010, 04:56 PM   #7
Exeter , California
Another question. What if a lengthend the toung put the bottles somewhere els and carried it up front against the fornt of the trailer?
Old 07-23-2010, 06:10 PM   #8
_
lp=100 lbs
bmw=500lbs
still a really bad idea.
even IF the A frame was reinforced for the load,
the tongue is now gonna be OVER 1200 lb, over 1400 lbs and probably more.
which means a big ass receiver.
and it's STILL TOOOO much for an H2
(there will be NO payload left for a driver)
the ONLY place to carry that load is INSIDE the stream,
or in the hummer.
just throw 'big momma' from the train first.
cheers
2air'
Old 07-23-2010, 06:12 PM   #9
Maniacal Engineer
barts's Avatar
Menlo Park , California
Well, that'll make for a lot of tongue weight and a lot of torsional load on the trailer frame in turns, and would carry a lot of weight higher than is desirable. Also, the trailer frame really isn't designed for such point loads. I'd focus on getting it into the rear of the truck. If your truck is heavy enough (350 or better), see if you can use a front mount receiver.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 05-23-2011, 04:24 PM   #10
Cousin Eddie's Avatar
2015 23' FB Flying Cloud
2003 25' Safari
Forestville , California
Want to make a great commercial for AS? Just hook the GS up to a dolly system and make it the tow vehicle.
Cousin Eddie is offline   Reply With Quote
I'm back. mrmossyone Member Introductions 2 10-31-2007 07:10 PM
I'm Back! Diana Langley Member Introductions 11 06-29-2007 08:38 AM
we're back... airstreamers Off Topic Forum 1 04-11-2007 10:51 AM
No going back now....... clancy_boy Cleaning, Stripping & Polishing 14 06-19-2006 08:11 PM
Odd back-to-back eBay auctions .... summerkid Trailer Values 5 09-12-2005 12:34 PM
