Old 12-29-2007, 05:49 PM   #1
spat61's Avatar
2003 31' Land Yacht 30
New Bern , North Carolina
Battery Sulfur Odor
I'm throwing this out as a thought because I have a persistent odor in my RV that I bought used. I tried all of the suggestions you good folks have recommended, including sewer gas, propane gas, holding tank remidies, 360 degree vents, clogged vent pipes, on and on. Just as a last effort I would like to throw out the possibility that the coach batteries are creating sufur gases that may be permeating the MH while it is sitting. Once I drive off, the odor disapates. Can the two up front coach batteries cause a real bad odor? I can't tell how old they are because the seller did not punch out the month and year from the label. Thanks.
spat61 is offline   Reply With Quote
Old 12-29-2007, 05:51 PM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
What model and year coach do you have? You signature says you are still looking.
It is possible but those are supposed to be sealed from the inside. Due to hydrogen gas.
I would keep looking for a black/grey vent or line leak. My vaccum break under the bathroom sink went bad. Anytime I ran a fan sucking/blowing out it stunk.
Michelle TAC MT-0
Sarah, Snowball
Old 12-29-2007, 05:56 PM   #3
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Batteries can discharge hydrogen sulphide if they're being overcharged. You might check the charging circuit. Old Univolts can due this.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
musty odor Elaine and Bohdan Dehumidifiers & Ozone Generators 20 12-08-2015 12:18 AM
mysterious odor sparky5 General Repair Forum 15 01-21-2008 01:39 PM
Interior Odor 640fan Waste Systems, Tanks & Totes 9 09-23-2006 08:57 AM
Rotten egg / sulfur smell niss1679 Electrical - Systems, Generators, Batteries & Solar 17 10-17-2005 06:08 PM
How to get rid of odor happier General Interior Topics 19 07-07-2004 10:34 PM
