Old 01-01-2003, 05:51 PM   #15
LOST , Hawaii
12VDC output of the alternator spliced to a wire that runs to the voltage regulator.
Straight into the regulator with another output wire, or is it in parallel with the output of the alternator?
John
74Argosy24MH is offline   Reply With Quote
Old 01-01-2003, 06:15 PM   #16
26Argosy.ca's Avatar
Cardigan , NB
This setup was done before I bought the MH, so I don't know what was done in terms of wiring. I hope to find that out in time...
Anywho, I have a big switch in front of the heater core that switches from battery 1, battery 2, Both or None.
The isolator is on the drivers side, on some sort of homemade bracket.
There is a regular car battery in the center, and the second battery was put behind and below the drivers seat, and is a deep cycle monster which is or has leaked and has corroded some of the metal. In an earlier post I asked about changing it...
This setup seems to work fine for me.
26Argosy.ca is offline   Reply With Quote
Old 01-01-2003, 06:30 PM   #17
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
There are 2 wires that go into the regulator there is one that attaches to the 12 volt block on top of the frame near the alternator the other goes into a wire loom. The output from the alternator is also attached to the 12 volt block. So I guess that makes it parallel??? I do not know where the other wire ends up.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 01-02-2003, 03:00 AM   #18
LOST , Hawaii
There should be another heavy wire coming off the terminal block that eventually goes to the battery. It probably goes to the lug on the solenoid and charges the battery like that. You need to get this out of the circuit and run a wire straight to the input of the isolator from the block.
John
Old 01-12-2003, 08:27 AM   #19
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I have the regulator sense wire connected to the output side of the isolator. HWen I run the engine I have a 17 volt reading at the dash meter for the engine battery, I did not run it long enough to check the coach battery.
I am going to move the regulator sense wire back to the output side of the alternator to see if I get a more normal output.
Brett G
Old 01-12-2003, 09:37 AM   #20
LOST , Hawaii
There is a fairly substantial drop across the isolator because of the diodes. If you move it the voltage should drop.
John
Old 01-12-2003, 09:00 PM   #21
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
The voltage after moving the regulator feed is now in line with what I expected to see on the dash gauge.
Now we will see if it works like it is supposed to this weekend. I also spent time replacing the dead house battery, and stripping tie wraps and looming the wires that run all over the front of the engine compartment. I have to get it neat before Mystic Springs because you are all going to want to see my shiney new carb.
BTW the carb came and it was the wrong one. I musta fat fingered the order form on line. I am returning it for the same CFM, but with the reccomended electric choke. So the Carb project has to wait until the week of the 20th, oh well, jsu more time to do dress up.......
Brett G
battery isolator kooblekidz Airstream Motorhome Forums 5 08-28-2003 06:04 AM
vintage airstream battery wildcat455 Electrical - Systems, Generators, Batteries & Solar 4 07-02-2003 12:50 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 08:43 AM
Battery Isolator shelocta Airstream Motorhome Forums 1 10-29-2002 10:32 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
