Old 04-15-2018, 03:16 PM   #1
Houston , Arkansas
Battery disconnect
How/when should I use the battery disconnect?
dreina is offline   Reply With Quote
Old 04-16-2018, 08:19 AM   #2
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Generally disconnect when storing your rig or when you are not using it for an extended period - like a week or more. Also may depend on what motorhome you have. It wasn’t in your profile.
- - Mike
Old 04-16-2018, 10:55 AM   #3
Houston , Arkansas
Thank you for the quick response. Everything I read was clear as mud. Thanks
Old 04-16-2018, 05:53 PM   #4
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
The worst thing you can do to your batteries is allow them to discharge completely. There are soo many things in a MH that can run your battery down. Simply leaving a closet light on and closing the door and leaving it sit for a week or so can totally discharge a battery. I turn my disconnect off any time I will leave it for more than a day. It's a pain to reset your clock and radio presets but, it's worth the peace of mind.
Gregsch is offline   Reply With Quote
Old 04-16-2018, 06:23 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
People on this forum do want to help you!
In order for you to get the help you need, you have to provide appropriate information. Specific information about your vehicle would be the first thing (trailer or motor home?, class if motor home?, model of vehicle?, year?, length?, etc). Many forum members either add this information to their signature (below) or avatar (left). This is done at the blue tab in the upper left that says "User CP" (user control panel) and "Settings" then follow the instructions.
Regarding your question;
The use and function is not the same for the battery disconnect on all Airstream models. There are manual switches, (a dial that is turned or a lever that is tripped) and push button switches on some. Without knowing what you have it is impossible to give you specific advice.
Generally, the disconnect is turned to the "USE" position while the trailer is being used and "Store" when it is not used for an extended period. This is done to preserve the battery. "Store" does not disconnect certain things on certain models (propane leak detectors are always on in either switch positions) In "Store" lights, furnace, refrigerator, radio, etc are some of the things that do not receive battery power.
Do you have an Owners Manual? The answers are there. If you do not, once you post your answer and information, I will be glad to provide a web link so you can download one.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
A W Warn is online now   Reply With Quote
Old 04-16-2018, 07:12 PM   #6
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
My 2009 Classic battery disconnects (storage) position does NOT turn off propane detector. It is hard wired to the battery from the AS in Jackson. So if you think that turning the battery switch to storage you have turned off all electric power to the trailer, no you haven’t, disconnect the battery cable at the battery.
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
To disconnect or not to disconnect urnmor Towing, Tow Vehicles & Hitches 36 02-22-2017 10:24 AM
Battery Disconnect Switch, Solar & AGMs SilverGate Batteries, Univolts, Converters & Inverters 29 11-03-2010 10:52 AM
Car Battery Low Disconnect in '68 crair Batteries, Univolts, Converters & Inverters 3 06-13-2006 05:29 PM
Battery Disconnect Light FiveGreers Electrical - Systems, Generators, Batteries & Solar 2 04-03-2006 08:01 AM
