Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 07-02-2003, 05:40 PM   #1
torin knorr
Profile:
Lightbulb Bad Smog Pump?
I have a 1985 270 MH w/ 65k miles, I have replaced the fan belt 4 times on the alt/smog and finally think they have it right. turns out the smog pulley was missing. Now I get whining noise when I accelerate and stops for a moment when I left off the gas. Could this noise be from the smog pump? Also I know that the alternator is from a local parts house. My information that I got shows that it came with Lestek alternator and seperate regulator.. Any thoughts?
torin knorr is offline   Reply With Quote
Old 07-02-2003, 06:30 PM   #2
PeterH-79MH
PeterH-79MH's Avatar
Profile:
Images: 63
since it stops when you let of the gas, it does sound like a loose belt. Did that noise start right after the belt replacement or after you drove some miles?
Once you figure out how to do it,
the instructions actually make sense.
_____________________________________
WBCCI Member at Large
PeterH-79MH is offline   Reply With Quote
Old 07-03-2003, 09:25 AM   #3
torin knorr
Profile:
bad Smog Pump
The belt is new with 150 miles on it. It may just need to be tighten. I am gun shy of over tightening. Thanks
Will give it a go
Water Pump David Hall Water Heaters, Filters & Pumps 8 01-12-2004 08:31 PM
Onan Fuel Pump swebster Mechanics Corner - Engines, Transmission & More... 20 11-06-2003 04:35 PM
Time for a new demand H2O pump thenewkid64 Water Heaters, Filters & Pumps 14 09-26-2003 01:34 PM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 10:16 AM
need plumbing map for water pump silverbullet Water Heaters, Filters & Pumps 1 09-22-2002 09:13 PM
