Old 05-31-2018, 10:03 AM   #1
Mike1997's Avatar
1998 36' Land Yacht Widebody
Shepardstown , West Virginia
Images: 14
AUX Start Switch
Appears my Aux start switch on the dash is not working and the Propane generator will not start, acts like the battery is dead. All 4 batteries test normal.
Where are the fuses or internal connections for this switch? Keep in mind this is a diesel so I have a large firewall compartment on the front end. The main transfer switch for 12v and shore power is in the bedroom. Everything else works normal.
Any suggestions would be helpful.
Mike1997 is offline   Reply With Quote
Old 06-04-2018, 01:17 PM   #2
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Have you cleaned the terminals on both ends of the cable to the generator? + and -
mayco is offline   Reply With Quote
Old 09-16-2018, 07:09 AM   #3
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
It may be different in your diesel, but on a gasser, I would test the solenoid on the back of the battery tray and isolator in the engine bay.
Boom Sounds is offline   Reply With Quote
Soft Start - Easy Start - Smart Start..? JConsroe Generators & Solar Power 13 06-16-2017 07:36 AM
starter aux switch Farm 1 Airstream Motorhome Forums 9 06-25-2014 11:57 AM
battery aux switch Farm 1 Batteries, Univolts, Converters & Inverters 0 10-17-2013 06:04 PM
My RV will start using the Aux Start but not with the chassis battery mcm9970 Land Yacht/Legacy Motorhomes 7 05-19-2013 07:47 PM
Cutter 99 aux hd lts switch landmarc Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 08-03-2010 06:48 PM
