Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 03-13-2008, 02:31 PM   #1
Vickig46
Profile:  Magalia , California
AS MotorHome fuel nozzle problem
The State of CA (in its infinite wisdom) has decided that all the fuel pump nozzles have to be upgraded to some wonderful standard but the compartment which the nozzle goes into on our AS will not accept the new nozzle (different shape and length). We actually got it stuck trying to force a new nozzle in and almost did not get it out (the gas station attendant wanted to tear apart the compartment). Anyway, I called Airstream and they had not heard of this problem. I cannot believe that we are the only ones with this problem - anyone heard of it or have a solution?
Vicki G.
Vickig46 is offline   Reply With Quote
Old 03-13-2008, 02:41 PM   #2
bkahler
Profile:  Jefferson , Arkansas
Wow, you got my attention on this one. I can see it now, we're all going to have to carry adapters around to allow us to fill our gas tanks.
Anyone else have any info on this change?
"Wherever you go... there you are." - Buckaroo Banzai
1984 310 Limited Motorhome
1974 31' Excella 500 (future hauler for 2 Triumph race cars)
1974 20' Argosy Motorhome (future Excella 500 tow vehicle)
Old 03-13-2008, 02:47 PM   #3
jayray5
Profile:  1973 25' Tradewind
Romulus , New York
vapor recovery system
If you pull the rubber accordian hose back before you put the nozzle in tank it will work fine. You have to babysit the nozzle while fueling.
jayray5 is offline   Reply With Quote
Old 03-13-2008, 03:08 PM   #4
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
I've never seen a diesel nozzle with a rubber boot, and I've never heard of anyone having this problem. We do spend a fair amount of time at the fuel pump, and it seems like we would have heard the cussing if it was a common problem.
You may have grabbed a high flow nozzle which is a larger diameter that the one designed for "passenger" vehicles. The high flow nozzles are for trucks, busses, fire engines, etc.
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 03-13-2008, 03:11 PM   #5
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Just filled my 77 no issue here on the right coast.
Interesting though...
Keep us posted on what you find out???
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'77 20' Argosy MH (Peanut)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is online now   Reply With Quote
Old 03-13-2008, 03:32 PM   #6
Vickig46
I just spoke with the dealer where we bought the rig - never heard of this and had no solution. Hubby says he tried pulling back the rubber on the nozzle - did not work. This is not just a one station incident - the station where we normally get fuel was our first experience with the problem and they had just changed - the attendant said that alot of the older vehicles were having problems (our AS is a 2003). The stuck nozzle was the second time we had the problem. Now we call ahead to ask if the station has changed the nozzles out (which can be a pain if you are on the road), but this also leads me to believe that all of them will change at some point.
Old 03-13-2008, 04:00 PM   #7
Fyrzowt
Fyrzowt's Avatar
Images: 8
Vicki,
I appologize for the info in my earlier post, I re-read it and see that you were probably talking about a gasoline pump, I had it in my head that this was a diesel pump.
I used to have a Chevy Nova that was very difficult to fuel.
I was/am unaware of any change in nozzle stds and would be interested in what you learn.
Dave
AIR #15800
2000 Safari SS 25'
Old 08-23-2008, 09:30 AM   #8
Vickig46
Solution???
Well here we are several months later and the problem has been solved. Not a perfect solution, but we can legally fill the gas tank. Our Airstream Motorhome has a small exterior door with the opening to the fuel tank inside the door. The opening for the fuel tank is recessed and slightly lower than the door opening. It was encased in plastic around the opening of the tank. After asking every place we could think of for a solution and coming up blank we had the repair person cut out the plastic that was around the opening, now the fuel nozzle goes all the way into the opening without getting stuck. This is really hard to explain for a non technical person, but perhaps you get the idea. There is no really good solution that we could find, but this will work. I assume this is a California problem.
Vicki
Old 08-23-2008, 11:38 AM   #9
345bill
Profile:  Las Vegas , Nevada
Havn't had that problem filling the MH here in NV. but you just reminded me of a incident I had last week getting gas. Normally use Chevron but because local Texaco is cheaper, and they have good soapy windshield water, I decided to try them. Their mid-grade gas label is green as is the diesel nozzle which is on the same pump. So here I am cussing at the pump, with diesel nozzel in hand, because pump would not turn on when I realized what I was about to do. After a good laugh I replaced the deisel nozzle, grabbed the mid-grade one, hit the green button and began fueling as I said to myself "ANOTHER SENIOR MOMENT".
345bill is offline   Reply With Quote
Old 08-23-2008, 12:33 PM   #10
zamboni
zamboni's Avatar
Profile:
That would ruin an otherwise bad trip to the gas station.
zamboni is offline   Reply With Quote
Old 08-23-2008, 02:05 PM   #11
345bill
bkahler- no info on that change but I do remember when unleaded first came out and alot of stations still only had choice of regular/premium pumps that had a fatter nozzle so you did have to carry a adapter to slip over the nozzle in order to get gas without punching out the flap in filler neck.
Old 08-23-2008, 05:14 PM   #12
reday
reday's Avatar
Profile:  Old Hickory , Tennessee
Similar problem...
On the way to the Outer Banks a couple of years ago, I was a little too picky about where I was going to pull off the highway for gas and found myself absolutely needing fuel. The station I pulled into had one island I could get to and still pull around back to get out (you don't back up when flat towing). I waited until I could get up to the pump and got out to refuel. When I tried to insert the nozzle, I could not get it to go in... some kind of attachment advertising cigarets, beer or what ever kept the nozzle from going more than an inch or two into the opening. When you tried to fuel, it came right back at you. No way to take the #@$$ ad holder off the nozzle. Ended up having to drop the Jeep off in their parking lot and make my way to a small station on further in town down narrow streets. No fun. The bad thing about this situation is that you have no way of knowing when you will run into it again.
Ralph & Margie Day
Lizzy the Borderline Collie
Old Hickory, TN
2003 31' Airstream Land Yacht
2004 Jeep Liberty Toad
reday is online now   Reply With Quote
Old 08-28-2008, 07:16 PM   #13
str8strm
str8strm's Avatar
Profile:  Tujunga , California
in California
we just spent 6 weeks on the road from LA to Tahoe to Santa Cruz with no fueling issues in a gas 345 with mini cooper tow.
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Help! Diesel mo/ho fuel problem. Mike Leary Classic Motorhomes 12 06-07-2007 10:23 AM
Fuel Filling Problem Chaplain Kent Mechanics Corner - Engines, Transmission & More... 7 07-15-2005 01:21 PM
fuel problem shinola345 Mechanics Corner - Engines, Transmission & More... 33 09-13-2004 12:39 PM
Fuel problem solved George Mechanics Corner - Engines, Transmission & More... 0 09-06-2004 07:25 AM
