Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 09-22-2002, 11:07 PM   #1
CBBOB
CBBOB's Avatar
Profile:  1976 31' Sovereign
El Dorado Hills , California
Armrests-Drivers seat
The folding armrests on the drivers seat of my 92 MH are coming apart between the plastic protion and the uphostered lower. The
plastic retainers for the screw heads has sheared off.
1. Can anyone prpose a fix?
2. Are they available somrplace?
Any help would be appreciated. Thanks
CBBOB is offline   Reply With Quote
Old 09-24-2002, 05:59 AM   #2
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
Any good local automotive upholstry shop should be able to fix you up in no time. Especially since you still have all the parts.
You might also look under the seat and see who the actual Manufacturer is and contact them.
Good Luck;
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
sofa seat back susanborck 1993 Excella 1000 1 10-20-2004 06:51 AM
Suburban 3rd seat TomW On The Road... 1 01-21-2004 06:04 PM
power seat switch wb13798 Mechanics Corner - Engines, Transmission & More... 1 01-02-2004 05:55 PM
Toilet seat cover overlander76 Sinks, Showers & Toilets 6 07-27-2003 11:50 PM
1988 -345 Tires and Seat Belts MacInDaBox Airstream Motorhome Forums 15 12-12-2002 10:14 AM
