Old 10-29-2015, 01:08 PM   #1
Argosy fresh air vent
Since I pulled the Argosy into the shop a few weeks ago, in my spare time I've tinkering with various parts trying to get them ready for installation. Several years ago I dismantled the heater/evaporator box for the dash air system. When I took it apart I found that the hinges for the two flapper gates (fresh air in and air to cockpit) were rusted solid. The fresh air in was frozen open and the air to the cab was partially open.
I've since freed the flappers up using electrolysis although the fresh air flapper is still stiff so I'll likely replace the hinge.
The picture below was taken from the outside of the box looking through the fresh air inlet opening. The expanded metal in the back of the box is the opening into the cockpit by the passengers feet.
When the unit is set for fresh air both flappers are open and their is a direct path from outside straight to the passengers feet.
What I'm wondering is, is how important is the fresh air vent? If I remember correctly we used it from time to time on the 310 but for the most part the dash AC was preferred.
Assuming I leave the vent in place would it be a good good idea to baffle the vent so rain can't be blown straight into it?
Old 10-29-2015, 04:58 PM   #2
1982 28' Airstream 280
Redwood City , California
I wish the classics had fresh air vents!
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 10-29-2015, 05:23 PM   #3
Dean, that's interesting. For some reason I thought our 84 310 had a fresh air vent, guess I need to check into whether it really did or not. I know Airstream went through several different choices for heat/ac boxes through the years. Maybe some had fresh air vents and others didn't.
On my Argosy the way the air box is installed if you're driving 70 mph the passenger should be getting a pretty good blast of air right on their feet.
I guess maybe I'll fix the hinge and keep the fresh air vent functional
Thanks!
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 15 07-21-2015 08:51 PM
'76 Argosy have vent pipes at roof (nicro vent install idea) BrianD. Waste Systems, Tanks & Totes 6 11-08-2014 06:28 PM
fresh water tank air vent cindy Fresh Water Systems 6 10-26-2004 07:03 PM
