06-27-2017, 07:49 AM
Richmond
, Kentucky
Argosy / Classic Front turn signal lights
Ok, I give up. I'm usually pretty good at finding a part when needed but I've reached a point in my search for a replacement front turn signal light where I'm ready to give up and throw my hands in the air!
The light in the pictures below is the right front turn signal light for my Argosy. I think the Argosies and Classics share the same light assembly. I need to replace the left front light assembly and can't find anything that matches it. A 67 to 68 Chevy pickup turn light looks similar but the lens does have a slightly different shape and I think it's larger overall.
Have any of you Argosy or Classic motorhome owners ever sourced a replacement light and if so do you have a part number or a place to order from?!
Thanks!
1975 24' Argosy Motor Home
06-27-2017, 09:28 AM
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
06-27-2017, 09:29 AM
Richmond
, Kentucky
I finally got lucky and got a hit on google!
The light assemblies are GM # 916558 and they are....obsolete, imagine that
Searching google with the 916558 number I found a pair still in the original GM box. They weren't cheap but there aren't exactly a lot of alternatives out there so I guess it could have been worse. And I now have a spare light assembly
06-27-2017, 09:32 AM
Richmond
, Kentucky
Originally Posted by martin300662
Martin, just saw your post. These lights look very similar and would definitely work. They aren't identical (who cares) to the originals which tells me they are probably reproductions (again who cares) but they should fit and work just fine.
While you were posting your reply I had just found a NOS pair and bought them. Fortunately I didn't spend too much more than what these sell for.
06-27-2017, 09:41 AM
1984 27' Airstream 270
Scotia
, New York
I think it is the same type they use in my 84
06-27-2017, 09:51 AM
Richmond
, Kentucky
Wayne, I believe that is correct. From what I remember I think all of the Argosies and Classics up to at least 89 or so used the same front turn lights.
06-28-2017, 01:01 AM
1989 34.5' Airstream 345
Saint Petersburg
I got replacement lenses from one of the Chevy Truck catalogs. Once it's day light, I'll get out there and see where they came from. Believe they also sold the whole light unit as well. I bought LED light pads and glued them onto the new lenses though.
Derek
06-28-2017, 01:40 AM
Saint Petersburg
06-28-2017, 06:43 AM
Richmond
, Kentucky
Derek,
After much searching yesterday morning I stumbled across a pair of NOS light assemblies and decided to buy them. Then Martin and now you pointed out there are reproductions that work just as well. If I hadn't found the NOS units I would have gone with reproductions. I'm just happy the lights are still available!
Thanks!
06-08-2018, 02:27 PM
1986 34.5' Airstream 345
Clamensane
, PACA
Derek
Hello
Where did you find it in lmc truck ?
06-08-2018, 04:02 PM
1969 25' Tradewind
Shasta Lake
Check http://www.lmctruck.com in the 73-87 pickup catalog pg.200 these may be what your looking for.
06-08-2018, 10:35 PM
1977 20' Argosy 20
Arlington
For my 1977 Argosy, I purchased 1967 Chevy Truck Park/signal lamp assemblies and they fit just like the originals.
06-08-2018, 11:49 PM
Clamensane
, PACA
Thank you so much for you’re answer
The one ok the right top corner
36-4414 ?
http://www.lmctruck.com/icatalog/CB/full.aspx?page=194
06-08-2018, 11:56 PM
Clamensane
, PACA
Originally Posted by Glenritas
Thank you for you’re answer
I maybe found one who can fit page 194 Chevy GMC truck
06-09-2018, 12:17 AM
Clamensane
, PACA
The one on the left top corner ?
Ref : 36-4414 ?
03-26-2019, 09:14 PM
1978 28' Argosy 28
Killeen
LED turn signals
Anyone know a way to convert one of these from bulb to LED? I found the kit to do the Argosy rear lights but no luck on fronts.
03-27-2019, 06:06 AM
Richmond
, Kentucky
I used these 1157 LED Amber bulbs on my 75 Argosy and Peanut which is a 77 Argosy. These bulbs should work for all of the Argosy and Classic series motorhomes.
03-30-2019, 06:41 PM
1979 24' Airstream Excella 24
Tipp City
, Ohio
I tried to switch the turn signal bulbs on my 79 classic to LED and found that there was not enough resistance in the LED bulbs to make the flasher work. I ended up putting the standard bulb back in .
All of my running lights have been converted to LED so the majority of the current draw was eliminated but , the turn signals work as originally designed.
03-31-2019, 07:10 AM
Richmond
, Kentucky
Greg,
I replaced the turn and hazard flashers with two of these flashers from Amazon.
They work great.
04-01-2019, 05:09 PM
1978 28' Argosy 28
Killeen
Originally Posted by bkahler
I know others have posted about changing the bulb out to an LED one. Hadn't heard that the flasher wouldn't work. Thanks, both for the info.
