Old 09-24-2014, 10:44 PM   #1
1979 24' Airstream Excella 24
Woodland Hills , California
Anybody installed 3 point seat belts?
I'm getting ready to install three point seat belts.
Has anyone done this installation to their moho?
I see the structural support adjacent to my driver/pass. windows
I've heard the support is only 1/8" thick , so I will need to reinforce the support rib. I plan on installing a steel plate, w/ 4 bolts into the structural rib for the shoulder support point.
Any thoughts?
Appreciate any input.
flatouf is offline   Reply With Quote
Old 09-24-2014, 11:52 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, this may or may not help, but I spent years trying to figure out how to install shoulder harness belts in my 1959 Ford Galaxie. The floor mounts were easy; Just holes in the floor with huge washers under the floor. the hard part was figuring out how to mount the "D" ring. I finally decided to drill a hole all the way through my "B" pillar post and I used a lug nut stud going all the way though the pillar post. This was the easiest and strongest way that I could come up with.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-25-2014, 05:27 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Just to make sure, you do know that three-point belts are not required, don't you? Motor vehicles, including motor homes, are only required to meet the Federal Motor Vehicle Safety Standards (FMVSS) that were in effect at the time the vehicle was built. So if it originally didn't have shoulder harnesses, it doesn't legally need them now, either.
I don't fault you for wanting to do itó safer is always better. I just wanted to point out that you don't have to do it.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-22-2016, 12:43 PM   #4
2014 Interstate Ext. Coach
The Woodlands , Texas
Installing three point seat belts in older Airstream Interstates
My wife and I have signed a contract to purchase a used 2010 Airstream Interstate built on a Freightliner chassis. We will pick up the vehicle from the dealer (about 250 miles away) in early December. It appears that some 2010 models (2010.5?) are built on the newer Mercedes chassis equipped with the second generation 3.0L V6. The vehicle that we are buying differs in at least two important respects from the newer 2010 model. First, it has a first generation 3.0L V6 engine rated at 154 hp (which we plan to increase using a Green Diesel Engineering Eco Tune). Second, it only has lap belts in the second row captain's chairs which we want to upgrade to three point belts. As a result, I am gathering information from as many sources as possible and would like to hear about others' experiences regarding the installation of three point belts in older Interstate RVs.
There is an extensive discussion (over 1000 posts) regarding Green Diesel Engineering Eco Tunes at sprinter-source forums web site. For a condensed version see http://sprinter-source.com/forum/sea...archid=2725559.
ponderosaTX is offline   Reply With Quote
Old 11-22-2016, 07:44 PM   #5
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
IMHO you'd be better off installing a late model truck seat with the shoulder belt integrated into the side of the seat. You could even run power to power the seat and get a nicer seat to boot for long distant driving. Safety wise I think this would be the way to go.
Yes, you would have to have a metal fabricator fab up some mounts for the seat, but it could be done.
http://www.newseatcover.com/newusedseats.html
Cheers
Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 12-11-2016, 09:08 PM   #6
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Used truck seats might be the only option, with a well thought out and seriously fabricated mounting system. No one wants to be launched through the windshield while firmly belted into their seat!!
I looked into aftermarket and used RV seats with integrated 3 point belts. Vendors will not sell them to you without serious documentation that proves that the seat will be going into a vehicle that was factory engineered to use it. Good old C.Y.A. at work. The fear of legal liability runs the world these days.
streamquest is offline   Reply With Quote
Old 12-12-2016, 05:36 AM   #7
2012 19' International
Southeastern MI , Michigan
Be careful about installing shoulder belts in a vehicle that was not engineered for them, like an older motor home or vintage car.
2018 International Serenity 27' FB
Goodyear Endurance tires
Hensley Arrow hitch
Tow Vehicle: Ford Superduty crew cab 6.2L V8
Countryboy59 is online now   Reply With Quote
Old 12-12-2016, 06:37 AM   #8
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Can you please elaborate on your statement? Thanks !
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 12-12-2016, 08:15 AM   #9
I'd like to hear the reasoning as well.
Old 12-12-2016, 01:32 PM   #10
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Reinforced point of attachment.
And the design such that the lower belt stays below the hip bones and the upper doesn't break your neck.
Meaning belt and seat design must work together for three point.
"Submarining" out of the belt in a rollover kills/injures many.
Etc.
More to it than this.
Old 12-13-2016, 11:42 AM   #11
german6563's Avatar
1977 24' Argosy 24
Hilden , NRW
Here in Germany the motorhome comes with these seats, well fixed to the ground and has three safety points
german6563 is offline   Reply With Quote
Old 12-13-2016, 12:07 PM   #12
Etc.
The reinforced points of attachment should be standard for the lower attachment point, the difficult but not impossible one for the older Airstream motorhomes is the upper attachment point for the shoulder harness.
Submarining has nothing to do with the shoulder harness which is what the subject was about.
You definitely don't want the shoulder attachment point to be lower than the shoulder blades or you can suffer compression of the spine in an accident.
Old 12-13-2016, 03:24 PM   #13
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Submarining is certainly part of it.
And the lack of approved design attaching points (standard factory item for year of manufacture) plus three point and seat designed to work together is what makes liability concerns high.
Old 12-13-2016, 03:44 PM   #14
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Trying to put an element of reality into the discussion, we are talking about adding a safety device to a vehicle that has the structural integrity of a cookie tin, and any collisions that impacts anything other than the chassis is going to be pretty disastrous.
martin300662 is online now   Reply With Quote
Is this a factory installed solar panel ? I think it's factory installed and ... JacobMerridy Electrical - Systems, Generators, Batteries & Solar 1 01-14-2017 09:23 AM
Seat belts and a few newbie questions jshaley Land Yacht/Legacy Motorhomes 7 08-31-2012 05:40 PM
Has anybody had this aluminum chassis/sub floor installed? JDavid Repairing/Replacing Floor &/or Frame 32 10-01-2010 06:40 AM
Adding seat belts and dinette bed Ellwallhome General Motorhome Topics 2 07-27-2004 08:57 AM
1988 -345 Tires and Seat Belts MacInDaBox Airstream Motorhome Forums 15 12-12-2002 09:14 AM
