Old 01-22-2003, 10:53 PM   #1
white1949's Avatar
2001 36' Land Yacht XC Diesel 300 hp w/slide
Dillon , South Carolina
Question amateur radio connection
Need help with or suggestions for antenna for 10,20,40,75 meter HF amateur frequencies to be mounted on 35 ft. Cutter w/ fiberglass body. Would like to mount on rear receiver using 6 ft. metal conduit attached to quick mount mobile mast. KF4BMZ for KA4BFY--David.
Carolyn
white1949 is offline   Reply With Quote
Old 01-23-2003, 05:03 AM   #2
Krazykraut
Guest
Posts: n/a
Amateur Radio
Are you talking about a CB radio or a Ham radio? Both have to have a good antenna ground wire to the frame of the vehicle.
Old 01-23-2003, 09:12 PM   #3
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
a screwdriver would work great on a fiberglass MH. IVE GOT ONE . I HAVE TO ELEVATE IT FOR MY CLASSIC . the swr is too high as the unit reflects a bunch back into the antenna.
wb4eze is my call lol
wb13798 is offline   Reply With Quote
Old 01-24-2003, 08:01 AM   #4
white1949's Avatar
MH Antenna
Thanks for your info. Would appreciate manufacture of the screwdriver. Will investigate further. 73 KA4BFY
Carolyn
Old 01-24-2003, 08:33 AM   #5
wb13798's Avatar
2004 28' Classic
got mine at a ham fest . i dont know of a company that makes the screwdriver couple of hams make them and sell at ham fest. and they sell like hot cakes. wb4kea bought one and mounted it on this pickup and i saw it played with it and i had to have one took. lol
al
Old 01-24-2003, 08:36 AM   #6
wb13798's Avatar
2004 28' Classic
also you could mount this antenna permanent to your rear bumper. your thinking that you would have to remove, dont have to. after it warms up outside i will take a picture of mine, so you will know what one look like.
Old 01-24-2003, 08:48 AM   #7
Gordon Watt's Avatar
A ham pulled into the camp ground with a huge monster motorhome. He used a vertical mounted on a tripod sitting on the ground. He said he uses 40 M most of the time and works great.
Of course the antennae broke down for storage.
Gord
VE4 IF
Gordon Watt is offline   Reply With Quote
Old 01-24-2003, 09:44 AM   #8
white1949's Avatar
Appreciate your help--will look for the Screwdriver
KA4BFY
Carolyn
Old 01-24-2003, 10:48 AM   #9
wb13798's Avatar
2004 28' Classic
hasnt warmed up too much but here is the picture . i have the pipe i use to mount to my tt mounted on this and what i did was drop it in a vent pipe . the antenna is from the black rubber mount up. top is a standard stainless whip. i called wb4kea and not answer when he calls me back i will pass on the contact info for the antenna.. this one you can mount it and forget it with your MH.
Old 01-24-2003, 10:59 AM   #10
wb13798's Avatar
2004 28' Classic
HERE IS A CLOSER VIEW OF THE ANTENNA . the base starts from bottom i have two wraps of black tape and them you see the top of the vent pipe, above that is the antenna.has a coax feed line and a two wire motor control lime use to tune to the different bands.
Old 01-24-2003, 11:49 AM   #11
white1949's Avatar
MH Antenna
Again thanks--neat instillation--looking into where to purchase this unit. your pictures came thru first class. 73 KA4BFY
Carolyn
Old 01-24-2003, 01:31 PM   #12
screwdriver antenna
A look on the web revealed a ham selling the screwdriver at this web site. http://www.qth.com/N7LYY/
This is the first I have heard of the antenna but, it does sound good.
Steve KC3RA
Steve McCarter is offline   Reply With Quote
Old 01-24-2003, 02:49 PM   #13
white1949's Avatar
Talking scredriver
Many thanks for the info--I'll check out the web site. KA4BFY
Carolyn
Old 01-27-2003, 01:10 PM   #14
wb13798's Avatar
2004 28' Classic
try tarheelantennas.com located in nc or http://hiqantennas.com/
the first one is the least expensive the later cost more.
lo al
cb radio, cassette radio jagcb750 Classic Motorhomes 14 04-19-2012 02:32 PM
Amateur Radio MoHo jking Classic Motorhomes 3 05-13-2007 08:48 PM
TV Connection to CD / Radio rear aux input tkowalyk Audio, Video & TV 0 03-18-2007 10:40 AM
Amateur Radio Club junbe WBCCI Forum 7 03-16-2005 03:03 AM
amateur radio antenna for motorhome white1949 Our Community 0 01-01-2003 10:17 AM
