Old 10-31-2005, 04:23 PM   #1
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Airstream name
O.K. I've seen lot's of different name plates but what is appropriate and correct for a 1984 AS MH? Is the individual name letters right? Or is it the driverside one piece molded name badge?
As my unit came without the AS name in lieu of a plate for the funeral home name plate I'm wondering if I can redo the engine access panel back to stock.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 11-03-2005, 03:25 PM   #2
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
My 1984 310 Limited has "A I R S T R E A M" across the hood in block letters. Do you want a picture?
guy99 is offline   Reply With Quote
Old 11-03-2005, 05:56 PM   #3
GlenCoombe's Avatar
Belleview , Florida
Images: 27
...D U M B...that's me. Asking a questions when I could have easily looked at my owners manual or the repair manual I bought! I know now that the letters are what I need.
The trouble is that my swing down access panel never had the letters installed and it would take quite a bit to line up and get all the little mounting points just right that I'm not sure this isn't a job best done by the factory.
Maybe I just need a new panel?
I'm very picky about plumb.
BTW thanks Guy99 for your answer.
Old 11-03-2005, 06:03 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
laser straight line, or chalk line
Glenn, why not pick up one of those laser chalk lines from your favorite hardware store? You can then sight along the line to get the letters straight.
Old 11-03-2005, 07:52 PM   #5
GlenCoombe's Avatar
Belleview , Florida
Images: 27
Oh I can make a straight line but A I R S T R E A M is nine opportunities to drill the mounting hole in just the slightest out of alignment to schew the letter out of not just level but square. Each letter has two mounting bolts if I'm not mistaken.
I'm not certain the factory has a template to go with a letter set....most of the units had these done on the assembly line. Mine of course got the other option.
Old 11-03-2005, 07:56 PM   #6
Well Preserved
1993 21' Sovereign
Set the letters on the line made by the laser, and mark the bolt locations on the hood with an indelible pencil, or sharpie marker. Then drill your holes. Piece of cake.BTW, the "T" should be centered right to left on the hood. You can measure from that.
Old 11-03-2005, 08:04 PM   #7
GlenCoombe's Avatar
Belleview , Florida
Images: 27
I'm not saying I won't try it but with my luck and nine letters I may need to wobble out a few holes to get 'em all lined up right. After all 9 letters 2 mount bolts per letter.... one handicapped DIY'er...and you've got the potential to make a real mess of a nice RV...he...he..he..
Old 11-03-2005, 08:07 PM   #8
Well Preserved
1993 21' Sovereign
Just remember to put the letters on right-side-up, and you'll be fine!
Old 11-04-2005, 08:09 PM   #9
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Glen, where did you get your letters? As you can see from the pic below, I need an "M". I placed an ad here in the classifieds, but no luck yet.
www.nesa.org
Air No. 6427
Old 11-05-2005, 05:24 AM   #10
GlenCoombe's Avatar
Belleview , Florida
Images: 27
Give me an EM!!
Jim & Susan, sorry to say that I've not found any letters yet. Have you checked with the factory? I assumed they would be an available part or more likely a full kit.
Old 11-05-2005, 06:42 AM   #11
Well Preserved
1993 21' Sovereign
Glen, as I was sitting here reading my coffee, and drinking the forum, er, umm, never mind.
Anyway, if you have to get used letters, chances are good that some of the mounting tabs will get broken off while removing them. I was thinking, a dangerous pursuit for me, and I thouhgt maybe you can just get 3M Plastic and Emblem adhesive, and glue the letters on. No drilling required, just nip off the lugs on the back of the letters. Another plus is, if you get a letter a little crooked, you have an opportunity to shift it a bit, without redrilling the holes. Also, the glue is clear, and dries clear, so if you get a little outside the letters, and don't get it wioped off before it dries, chances are very good no one will ever notice .
Old 11-05-2005, 07:02 AM   #12
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Glen,
How about a nameplate already spaced. Steve at Vintage Trailer Supply, formerly Airstream Dreams has this name plate and others. You can also talk to him abou the letters.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 11-05-2005, 12:59 PM   #13
Uberlanders's Avatar
1968 26' Overlander
Wenatchee WA , Cape Cod
This brings up a good point...what years had what nameplates. Is there a site that will tell you?
Jim & Kathleen
1968 Overlander - WBCCI #5793
Uberlanders is offline   Reply With Quote
Old 11-16-2005, 12:41 PM   #14
VintageRV's Avatar
1956 22' Caravanner
Montpelier , Vermont
Nameplate Years
The etched deco lettering plate that Kent shows is from the 1940s up through 1960. Most years had it painted blue, but some had no paint and a few seem to have had black paint.
This was followed by the larger etched blue plate (not deco) from 1961 to 1968. As with all things Airstream, there was a little overlap at the transition years Some 1968 trailers have the 1969+ individual cast letters.
Another nuance to the 1960s etched plates is that the California trailers generally did not have pre-drilled rivet holes in the plates and they were generally attached with 8 rivets. The Ohio trailers used a predrilled plate that had 6 rivets. Go figure.
Steve Hingtgen
WBCCI #1573
VintageRV is offline   Reply With Quote
Cost to restore a gutted Airstream Draco General Interior Topics 28 02-18-2013 11:17 PM
Late '80s Airstream Aluminum Fifth-wheel acwdgw Integrity 5th Wheel (all Years) 17 01-09-2004 10:20 PM
airstream! airstream! airstream! 83Excella Our Community 0 03-23-2002 10:37 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 01:31 PM
