Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 02-26-2005, 11:34 AM   #1
Airstream height
I'm interested in buying a smaller Airstream trailer....20' or less but
since I want to be able to garage it at home vs storage, the max height
I can go is just under 8'..the new Bambis are just over 8'. How about older
models? Anyone know?
nsxer is offline   Reply With Quote
Old 02-26-2005, 02:49 PM   #2
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
About the same. I just happend to measure mine recently. Its a 59. Its 6'7" floor to seeing add 5 inches for roof thickness and the vents. So 7ft without A/C plus 20 inches from ground to floor height.
The height has been pretty stable thought the years. With roof A/C figure 10ft to be safe especialy if the drive slops in and out of the garage. If its flat in and out then 9ft should clear A/C, about 8.5 feet no A/C and vents closed.
Airstreams are about the lowest fixed roof coaches on the market. About the only fixed roof I can thing of that will clear a standard Garage door is the T@B. Its a teardrop with just enough room to stand in. http://www.tab-rv.com/
Now older homes have 7ft doors not 8ft. I would measure yours to be absolutlly sture of the height.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 02-26-2005, 03:24 PM   #3
I have 95" max to work with.....thanks for the info. The newer Bambi
19' are 8'6"...so close yet so far! I had hopes that vintage models would
possibly be shorter in height.....
Old 02-26-2005, 07:18 PM   #4
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I believe they are around 9.5 feet for a vintage Airstream, with bias ply tires.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Airstream Height Earl Winterizing, Storage, Carports & Covers 25 03-22-2008 08:34 PM
... on being an Airstream Ambassador RangerJay Our Community 4 01-03-2005 08:57 PM
Airstream height Earl 1981 - 1983 Excella 1 09-01-2003 09:35 PM
airstream! airstream! airstream! 83Excella Our Community 0 03-23-2002 10:37 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
