Old 02-22-2016, 06:17 PM   #1
2016 28' Land Yacht
2006 30' Land Yacht Gas 30
Hartwell , Georgia
Airstream Diesel 35 1998 vs 36 2001, Your thoughts?
I am evaluating both a 1998 and 2001 Airstream Motorhomes and would love your insights. Big question,Is there much difference? Mileage is similar and one needs a bit more work than the other. My biggest concern is reliability. The older one is actually with a full service RV dealer and 2001 with private individual. You guys are the experts. Do you have any words of wisdom? N
NMoureau is offline   Reply With Quote
Old 02-23-2016, 10:08 PM   #2
Mike1997's Avatar
1998 36' Land Yacht Widebody
Ft. Lauderdale , Florida
Images: 14
Last year I bought a 97 Landyacht pusher on a Freightliner chassis with the 275hp Cummins. It had 46k miles and generator had about 215 hours. Was stored inside a warehouse since new and very well taken care of. Maintenance and exterior upkeep is most important. Check all the rubber gaskets and look for water damage from leaks. I put over 10k miles on it since purchased with trips to the Florida Keys, Great Lakes, and move to Montana.
So far the 3 most expensive repairs were all due to age vs usage.
1. It had play in the wheel. Freightliner said the bell crank assembly needed to be
replaced and its something on their recommended maintenance list at 10 years. At same time I had 4 original tires and shocks replaced and had the cooling system flushed. $3300
2. The Allison 6speed transmission went into a fail safe mode after about 5000 miles of driving. Freightliner said it was a pump in the transmission that went bad. $1800
3. On arrival in Montana the big furnace would not operate. It would start but shut off after 10 seconds. Turned out it had never been used and the computer board was bad $165
The new 2001 rigs are larger with slideouts. Mine is the widebody (no slides) with a washer/dryer and queen bed. Its draws lots of attention in campgrounds and I love how it handles. Pulling my Jeep Grand Cherokee it gets about 11mpg cruising at 65mph. I like how the front is aerodynamic vs the flat fronts.
If you have any other questions, I will be glad to answer individually. Lots of photos of my rig are posted under my profile. Mine came with all the original records and owner manuals.
Mike1997 is offline   Reply With Quote
Old 02-23-2016, 10:32 PM   #3
2016 28' Land Yacht
Hartwell , Georgia
Thanks for the feedback. Sounds like even with the repairs you got a nice unit. I just found out the 1998 was used by a smoke so that's out for me. The 2001 is still available but I am open to other older airstream motorhomes.
Old 02-28-2016, 06:14 PM   #4
Morrisville , Pennsylvania
1983 310 diesel
Do you guys think that 4500 dollars is a decent price for a 1983 Airstream 310 with turbo diesel 6 cylinder? It has 60,000 miles and is all original. Pretty good shape for the year with some dents here and there and definitely needs tires
Kzguy2 is offline   Reply With Quote
Old 02-28-2016, 08:25 PM   #5
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
That's dead cheap. If you don't buy it, please post contact info for the seller.
Waipio Rim is offline   Reply With Quote
Old 02-28-2016, 10:59 PM   #6
Thanks for the response. Im supposed to go look at it tomorrow. Pretty set on buying it if it doesnt have any serious rust. Ill post the info here if i dont buy it though!
Old 03-05-2016, 04:40 PM   #7
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Did you buy it? If so, post pics!
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 03-05-2016, 11:12 PM   #8
Nah, it needed way too much work. Another guys bought it for i think $3800
360 Classic Diesel - Need Thoughts! Bambi_Bandit Classic Motorhomes 14 03-15-2018 07:09 AM
Thoughts on 15 yr. old diesel Suburban? Eaglemate Towing, Tow Vehicles & Hitches 14 06-08-2012 08:12 AM
Considering a 280 Diesel? Any thoughts? altemplet Classic Motorhomes 12 03-31-2008 04:36 PM
Considering this Airstream - your thoughts? zander213 1960 - 1964 Overlander 11 06-02-2006 08:02 PM
Your Thoughts Please... tin can luv Our Community 11 08-24-2004 12:04 AM
