10-08-2015, 12:16 PM
2005 28' International CCD
Aurora
Air Conditioner Stops Blowing Hard
Replaced our Dometic A/C unit a year ago for our 2005 International. We have noticed that sometimes, after it runs a while, it stops blowing forcefully from the vents. Could it be freezing up? If so, what could we do to prevent this?
My wife loves it cold enough to hang meat (LOL). So we generally keep it going constantly when we are at a site with electric hookup - especially when we're vacationing in South Texas like we are now.
Chris
10-08-2015, 12:23 PM
2008 25' Classic
Full Time
Are you saying the fan slows down or it goes off. Is the thermostat set on Auto? Auto will run at high speed then kick down to low fan and when at temperature the compressor kicks off. I usually leave my 13.5K Dometic on Low Fan and it cycles the compress on an off but keeps the fan on 100%. I can't hear much difference between high fan and low fan on my unit so I leave it on low.
Kelvin
10-08-2015, 12:28 PM
1969 25' Tradewind
Shasta Lake
It's most likely freezing up.
Set the temp a bit higher so the compressor will cycle and allow the evaporator coils to defrost.
BTW a 28' would benefit by having 2 a/c units and using a auto switching unit to only run 1 at a time alternately.
10-08-2015, 04:39 PM
2012 28' International
Olympia
If it is humid set the fan to high to lessen the chance of icing.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
10-08-2015, 04:59 PM
2015 28' Flying Cloud
Newtown
, Pennsylvania
I have 2 A/C units. Where can I get an auto switching unit?
Bruce
10-08-2015, 05:22 PM
Olympia
Bruce
I don't think you need one. The thermostat will work just fine.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
10-08-2015, 06:15 PM
1969 25' Tradewind
Shasta Lake
The auto switch is used on rigs that are only 30amp so the 2 a/c's don't overload the main breaker.
If you have a 50amp rig you don't need it as long as the park has 50 amp service.
I suppose one could install one on a 50amp rig but it would require some rewiring of some circuits . So when the park has only 30amp service you could still run both a/c's alternately.
A competent RV shop could supply and install a unit.
10-09-2015, 11:08 AM
2014 25' FB Flying Cloud
Matthews
, North Carolina
I tried what the owner's manual recommends and it worked for us during one miserable trip in the Deep South; kept the fan on HIGH.
10-13-2015, 10:24 AM
Aurora
Thanks to all who replied.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
furnace blowing cold air
canine camp |
Furnaces, Heaters, Fireplaces & Air Conditioning |
55 |
07-26-2013 11:14 PM |
Air Conditioner Only Blowing at 50%
Fly at Night |
11 |
08-04-2012 10:55 PM |
Heat Pump/Air Condition Blowing Hot Air
Safari-Rick |
1 |
04-24-2012 08:30 PM |
Heat Pump blowing cool air?
craftsman |
11 |
04-08-2008 06:01 PM |
air conditioner air flow problem
strawberryjo |
0 |
06-05-2006 10:43 AM |
