Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 03-02-2003, 10:18 PM   #1
jim8860
jim8860's Avatar
Profile:
Air Bags
I just bought a 1995 33 1/2 Airstream Land Yacht. I took it for a few quick day trip to try it out and thi sis what I found. There is a green light on my dash to tell me that the air compressor is on for the air bags. The pressure gauge reads a pressure between 90-100 psi. I think that is normal but the light never turned off. I just took a long road trip (300+) miles and I noticed that the little green light was turning on/off, it never did that before. So I watch the gauge go from 70 psi to 98. I assume that the compressor was done filling the tank @ 98psi and the light goes off. My problem that this process takes only 1-2 minutes to cycle 98 to 70 psi. that it fills up again. Is this normal? Jim
jim8860 is offline   Reply With Quote
Old 03-03-2003, 07:23 AM   #2
PeterH-79MH
PeterH-79MH's Avatar
Profile:
Images: 63
Jim, not normal. You need to get the system serviced asap.
Once you figure out how to do it,
the instructions actually make sense.
_____________________________________
WBCCI Member at Large
PeterH-79MH is offline   Reply With Quote
Old 03-03-2003, 09:24 PM   #3
jim8860
jim8860's Avatar
Profile:
Well PeterH-79MH you are right!. I took you advise and I called the dealer and they said "well will take a look, but some air pressure loss is normal" I replyed "I guessed that thats how air bags work" So I call later and I talk to the shop foreman( he is very on the ball ) and he has a good idea what is wrong based on my problem. We should have a fix by tuesday. Keep you posted Jim8860
Old 03-08-2003, 08:51 PM   #4
jim8860
jim8860's Avatar
Profile:
Well I just got my MH back from the dealer and they couldn't find anything out of place.So I took off for my trip. About 600 in to the trip the right rear bag looks like it sprung a small leak. I now here air leaking all the time.Also my catalytic cloged up, I could even pull 40 MPH on a down hill run.So I took my trusty axe and started to hit the cat. it help out a lot .When I got to exit 27 on 81 in PA and found a great RV place at 4:15 they took me in and spent a good 35 min in the shop cutting a hole in the cat. so it can breath. When to the desk to pay I guessed $40-$50 dollars , and the man said "with tax $7.95" I said "great thanks" .and off I when.Here is there info if your are stuck good people.
Grumbines RV
7501 Allentown Blvd
Harrisburg PA 17112
717-657-3741
www.grumbine.com
Rear Air bags PeterH-79MH Mechanics Corner - Engines, Transmission & More... 24 11-12-2007 07:02 PM
Rear air Bags stuart2 Mechanics Corner - Engines, Transmission & More... 15 04-01-2004 01:32 PM
Air pressure for rear air bags Jon Smith Towing, Tow Vehicles & Hitches 2 08-12-2003 10:08 PM
'78 Argosy MH Air Bags edmatlock Airstream Motorhome Forums 2 06-20-2003 09:38 AM
