Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 10-14-2009, 05:22 AM   #1
Mr. D's Avatar
1988 34.5' Airstream 345
White Lake , Michigan
Air bag compressor on '88 345
Hi everyone,
Looking for information regarding the operation of the solenoid within my rear air bag system. I understand that it is supposed to released pressure when the psi from the pump reaches the proper level. I also understand that this is to create a no load situation for the pump when it is next called on to work. The problem is that currently my solenoid appears to be releasing to much pressure (much more noise than unsual) so much that once it releases pressure the pump goes back on and this cycle continues. This seems to be a new development after recently bringing it out of storage. I have released the moisture in the system with no change in the operation. I know there is a low and high pressure switch on the wiring scheme but I'm not sure how to check for proper operation of pressure switches and solenoid? Any suggestions, Mr. D.
Mr. D is offline   Reply With Quote
Old 10-14-2009, 07:55 AM   #2
Originally Posted by Mr. D View Post
Hi everyone,
The air can bleed back thru the compressor when it shuts off, when the small check valve goes bad.
Replacing the check valve stops that problem.
It's a small brass check valve that can be near the compressor, or under the coach, near the air bags.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-15-2009, 12:17 PM   #3
Mr. D's Avatar
Thanks, that's what I thought, I just can't find anything under the coach that looks like a check valve. What do you think about putting a second valve on line somewhere more reachable, on the pump side of the existing valve?
Old 10-15-2009, 12:23 PM   #4
You can do that, but remember, the air line tubing is steel.
You will have to carefully add a couple of threaded fittings.
Andy Rogozinski
Inland RV Center
Corona, CA
Air bag problems...help! Mike Leary Jacks, Stabilizers, Lifting and Leveling 1 04-06-2007 11:08 AM
Air bag problems ... help! Mike Leary Off Topic Forum 3 03-18-2007 02:28 PM
air bag air compressor dbyar Mechanics Corner - Engines, Transmission & More... 12 05-08-2004 12:58 PM
Air Bag alfalsetto Mechanics Corner - Engines, Transmission & More... 5 09-27-2003 09:16 AM
air bag compressor zamboni Mechanics Corner - Engines, Transmission & More... 2 11-19-2002 10:38 AM
