Old 09-29-2006, 10:35 AM   #15
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
I had the same exact problem. The shore power source connection had no ground (garage of old house). I rewired the shore power source to its own breaker (30 amp, 10 gauge wire) in the box with a ground and the problem went away.
Tom
tlavergne is offline   Reply With Quote
Old 09-29-2006, 10:58 AM   #16
1982 28' Airstream 280
Norfolk , Virginia
I also had the same problem, only it was with a campground in Canada. I moved to another site, problem solved. You might try plugging into another outlet on a different circuit and see if the problem continues. From another one who has ben bitten by the juice, BE CAREFULL.
Steve
Geophilist is offline   Reply With Quote
Old 09-29-2006, 05:05 PM   #17
tx-lawman's Avatar
1995 33' Land Yacht
Houston , Texas
Problem Isolated & Solved
Thanks for all the great feedback!
I have a portable Honda inverter generator that is supposed to shut down and indicate any shorts or ground leaks, so I plugged the motorhome into that generator to see what it says, and found that there was no problem or shocks when plugged into the portable.
I then ran the cord inside the house and plugged it into the laundry room plug (not the 220v, of course). No problem, everything worked great & no shocks.
Happily, I guess the problem was in the garage plug. This is the same plug I have always used, so I don't understand why this just started. I turned off the garage breaker on the house & I'll call an electrictian when I we get back from our trip.
Thanks again for all the help. I love this forum! (and it has saved me lots of $$$$$$)
____________
Troy Marrs
95 Land Yacht 33
tx-lawman is offline   Reply With Quote
Old 10-01-2006, 10:35 PM   #18
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, My garage only has two wires comeing from my house to the garage; Therefore, no ground wire. Why, I don't know. That's the way they were built in the fifties. Actually, the original wall sockets, in my house, were not grounded either. I think you never noticed it before because of lack of moisture. [sweat, wet, or humidity.]
A Shocking Experience dwvh2o Electrical - Systems, Generators, Batteries & Solar 5 07-03-2006 07:23 AM
Shocking Touch fastrob Electrical - Systems, Generators, Batteries & Solar 27 10-16-2005 05:04 AM
SHOCKing question...... Safari Tim Shocks 27 05-17-2005 07:50 AM
Safe from Lightning in an Airstream? maggieairstream Our Community 21 07-22-2003 04:18 PM
What shocks? Silver Annie Shocks 6 11-03-2002 11:14 PM
