07-06-2017, 10:55 AM
1998 31' Land Yacht
lafayette
A/C Electrical
Quick question I am reinstalling my interior & plugged an outlet tester in all the outlets & all show hot nuetral reversed. Wiring issue or function of converter?
We call ours "Ship Of Fools"
07-06-2017, 11:05 AM
1974 Argosy 26
Morrill
, Nebraska
Wiring issue.
What are you using to provide power to the coach?
If it is a standard household receptacle plug your tester in there and see what you get.
If you are plugged in to a 30 amp receptacle you will need a 30 amp to 15 amp adaptor to perform the test.
You can remove the power to the coach and check the distribution panel. All black wires should be connected to circuit breakers; all white wires should be connected to the neutral buss.
This includes the wires of the shore power cable.
07-06-2017, 11:29 AM
Richmond
, Kentucky
One thing to keep in mind on motorhomes and trailers. The neutral and ground wires should never be connected together EXCEPT at the generator. When connected to shore power the only ground connection is at the shore power entrance panel, where ever that might be located.
When running from generator the generator will tie the neutral to ground.
1975 24' Argosy Motor Home
07-06-2017, 11:34 AM
2002 30' Classic S/O
Fleming Island
I don't know about others, but the Honda 2000i keeps the ground and neutral isolated. This causes some surge protectors and/or transfer switches to fail to pass the power. The solution is simple, a plug with neutral and ground connected and plugged into the other outlet on the generator.
Al
07-06-2017, 11:56 AM
1998 31' Land Yacht
lafayette
Thanks to all. I'm plugged into 30a service in my shop. I'll ck further
07-06-2017, 12:33 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
First thing to check is the wiring on the 30A socket in the shop. Next thing to check is the wiring of the shore power cable. Once both are "known good" start digging into the trailer. The quickest way to check both is with a multimeter. The "hot" wire will read 110V to ground.
07-06-2017, 07:14 PM
1998 31' Land Yacht
lafayette
It was a reversed hot neutral in the shop outlet. And guess who put that in........me. 2 yrs ago & never noticed it.
07-06-2017, 09:23 PM
2007 22' International CCD
Corona
A/c Electrical
Well, at the very least you do know who to yell at for that error [emoji3][emoji3][emoji3]
And he'll have to listen...
Seriously, it's always a good idea to check stuff like this. I've had so-called professionals make similar errors...
