Old 08-10-2018, 06:38 PM   #1
2014 28' Land Yacht
Santa Rosa , California
79 Excella Windows help
My 79 Excella motorhome Windows all need new weatherstrip. It looks like the only way to get the fixed glass in the operational and non-operational frames is to completely remove all exterior rivets and pull the frames apart. What am I missing? Also, the door hinges are held by two large Phillips machine screws. They just spin when I try to remove them. ?
Carman is offline   Reply With Quote
Old 08-10-2018, 07:18 PM   #2
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Carman, looks like you are new to the forum. Welcome to the madness! You will find all the info you need here on the forum. You will have better luck getting the answers by posting in the Classic Motorhomes section rather than the General Motorhome section.
The windows are a common repair on these old girls. You remove the fuzzy schlegel weatherstripping to make room to remove the glass. There are lots of threads on the subject. I have some posts on the subject in my thread 'Countdown to kickoff" but, there are several more, just do a search.
As I recall when I adjusted my door hinges I had to remove the interior skin to get access to the screws. Sounds to me like a previous owner may have changed something. Here to, a search should come up with several threads on the subject.
Gregsch is offline   Reply With Quote
Old 08-10-2018, 10:23 PM   #3
2014 28' Land Yacht
Thank you.
Old 08-11-2018, 01:13 AM   #4
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Welcome!
You are correct about the fixed glass in the sliders. The vertical bar has to come out and that is fixed in place through the frame and only accessible when the window is removed.
martin300662 is offline   Reply With Quote
Old 08-11-2018, 10:49 AM   #5
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Here's a good thread on window removal:
http://www.airforums.com/forums/f311...ce-136024.html
Waipio Rim is offline   Reply With Quote
Old 08-12-2018, 09:56 PM   #6
1996 25' Excella
Shakopee , Minnesota
I had to replace my door bolts. What I did was to remove the door trim on the inside. I then measured very carefully and drilled a hole from the back side to align with the door hinge bolts. The size of the hole was determined by the size of the socket I used to put a nut on the replacement bolt. There is fiberglass insulation behind the skin. Be careful it doesn't wrap around the drill bit. I then drilled the head of the bolt off. I then was able to push it out thru the hole on the back side. Mine had some very sticky adhesive still hanging on. I found some stainless steel replacement bolts that had a hex head drive. Lot easier to tighten than a phillips head bolt. When done put some insulation back in the hole and cover with aluminum tape. Put the door trim back on. My cabinets were right next to the door so the door trim was tight against it. I ended up cutting the trim at the cabinet height to be able to remove it. Not very noticeable when done.
TimeForFun is offline   Reply With Quote
Upgrade Windows vs Hehr Windows??? TomR Windows & Screens 5 08-19-2009 05:08 PM
'Nice' Windows vs. 'Cheap' Windows on New Units AZ-JH Windows & Screens 10 05-08-2008 05:27 PM
Windows, windows, windows... Balquin Windows & Screens 4 07-04-2006 06:35 PM
Door windows vs. no door windows? Craftsman Doors & Locks 33 02-05-2006 07:29 PM
Windows-probs, Linux more prbs...back to Windows Kistler Off Topic Forum 13 11-04-2004 09:19 AM
