03-28-2007, 10:46 AM
#81
DixieDove
1978 Argosy 27
1978 28' Argosy 28
Camden
, Tennessee
refrigerator
My refrigerator quit working....or I should say....I'm sure it was working when I got the RV home....now it's not working. I think what happen is that I operated it in a very unlevel position. A book I have says that can make a refrig quit working. The book also says...it is worth a try...to take the refrig out and lay it on it's left side for a couple hours. My question....the book does not tell me which side is the left side. I am assuming that it is the left side as I am standing in front looking into the frig. I know this question sounds dumb...but the book says IT'S left side. Anyway....I've tried both sides and it does not seem to be working....does anyone have any tips on what I should check. Book simply says if laying on left does not work must replace unit. Hope that's not the case
Charles.
tn2... Bad thing about doing nothing is you never know when you're done.
03-30-2007, 09:53 AM
#82
1977 28' Argosy 28
1978 28' Argosy 28
Rockford
, Michigan
sorry for not getting back to you, I have been trying to figure out how to upload an image .........
03-30-2007, 09:54 AM
#83
1977 28' Argosy 28
1978 28' Argosy 28
Rockford
, Michigan
Hmmmm now I wish I knew how I did that...........
03-30-2007, 01:17 PM
#84
DixieDove
1978 Argosy 27
1978 28' Argosy 28
Camden
, Tennessee
pictures
Once you figure it out...let us all know how you did it....LOL
03-30-2007, 01:23 PM
#85
DixieDove
1978 Argosy 27
1978 28' Argosy 28
Camden
, Tennessee
Hey....I did it too
well something seem to work for me also...
One thing I did was reset my camera to a lower resolution...maybe that was my problem
Charles
I'm going to try one more
03-30-2007, 05:08 PM
#86
2017 27' Flying Cloud
Altoona
Originally Posted by betsy28
I just read your post(s). We also just bought an Argosy 28'! Although ours in mint condition (although completely outdated 70's fasion) We plan to redo the interior - lime green is just not our style- but we will do it in such a way that it will not be destroyed in case future owner wants to gp original. All the components appliances, switches and wiring works and is in original condition so, if you need photos of a place or a part to know 'how it was' or how it should be - I would be happy to help. Also, I have ALL the original manuals down to how the oven works and a recipe book for 'cooking on the road' I could have any of them copied for you - let me know what you need and I can get a cost from Staples to copy and bind. Good luck with your project. We just love our 'Betsy' she may be alittle outdated but they just don't make them like they used to - she makes the newer RVs we looked seem like milk cartons on wheels. These are just such solid vehicles. What kind of Gas mileage did you get traveling? Did you use Premium grade. The man who owned ours previously said they run better and get better milage on Premium.
I'm interested in your comment about premium fuel. Most of the older 454's run fine on regular so there is absolutely no advantage to using the big bucks $$ stuff. If your engine does not ping under throttle, do not waste your money. Pay attention in high altitude and when going up steep grades. I do spend the extra $$ on synthetic oil.
03-30-2007, 07:23 PM
#87
reg fuel
I also have a 454 in my 77 24ft. argosy. It runs fine doesn't ping. I have driven it across Canada, down to Yuma. It runs as good at sea level as over the mountains. It runs in hot weather and freezing weather. I also use regular Oil. Change oil and filter every 2000,3000 miles.
irwin
03-31-2007, 01:45 PM
#88
DixieDove
1978 Argosy 27
1978 28' Argosy 28
Camden
, Tennessee
fuel
I drove 1600 miles from PHX to TN and used low lead all the way.....didn't notice any problems even at higher altitudes. 454 engine with a fresh tune up....so maybe that helped.
03-31-2007, 03:16 PM
#89
1985 34.5' Airstream 345
Tujunga
We have put about 5,000 on our 345 since we got it. the 454 seems to run fine on the lower octane fuel. I have not tried the premium, so I don't know if premium would provide any advantages.
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
04-01-2007, 09:50 AM
#90
1977 28' Argosy 28
1978 28' Argosy 28
Rockford
, Michigan
someone said that they had "all the manuals"? does anyone have the wiring diagrams for the coach itself? I have the diagrams for the chasis.. but what that did in the factory while building the upper sectoin would really help.
04-01-2007, 09:51 AM
#91
1977 28' Argosy 28
1978 28' Argosy 28
Rockford
, Michigan
and mine will idle on just about anything.... but starting out from a stop usually causes some chugging and lack of power. it sat for almost 5 years with no care so I think that i have a carb rebuild job in the future.
some of you have replace some of the sub flooring, are you using marine ply or just an exterior ply?
04-01-2007, 10:04 AM
#92
1977 28' Argosy 28
1978 28' Argosy 28
Rockford
, Michigan
painting....... cost.... prep.... yikes.....
in the Navy we used a system called a vacueblaster. it worked like a sand blaster, but was contained with in a vacume that all particles were sucked up as it clean the paint off the side of the aluminum (sp?). It also used baking soda (not sand) that when you were done you washed the trash bin with water melting the baking soda leaving just the paint particles to be properly handled. does anyone know you can rent such a tool. prep work might save a lot of money on the paint job.
04-07-2007, 08:12 PM
#93
DixieDove
1978 Argosy 27
1978 28' Argosy 28
Camden
, Tennessee
Flooring
Finally got the wood flooring installed in the Dixie Dove. I was supprised at how easy it actually was to install. I installed a glueless....snap together type floor. Would be a lot easier if everything was removed...i.e. refrig....sink....etc.... but I didn't do it that way....had to make several cuts around things but I think it turned out ok. Now I am waiting on getting my chairs back from being reupholstered....can't wait. It is so nice to see things going back together
Charles
04-20-2007, 06:44 AM
#94
1977 28' Argosy 28
1978 28' Argosy 28
Rockford
, Michigan
that is a beautiful looking floor........ congrats.
03-25-2024, 03:54 AM
#95
1976 Argosy 28
Spanish fork
, Utah
New to the crew
Hello! Not sure if y’all are still posting on here or not. I just purchased a 1978 Argosy 28ft. There are some things I need to replace or upgrade but for the most part, she’s ready to cruise! I have the complete manual for my rig, if anyone is looking for one (a copy of course). Main things I’ll do right away is replace side mirrors, windshield wipers, dash and gauges (she runs, I just don’t know how fast, how much gas, etc), seatbelts for kids and a backup camera.
I don’t think I’ll attack the dash until the fall/winter 2024. I would love pointers, suggestions and things to avoid, etc. Thanks soo much!
03-25-2024, 05:11 AM
#96
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Hi Stevie
Welcome to the forum.
The Argosy motorhome sub-forum is a little quite at the moment (the whole classic motorhome section is for that matter) and we need a project to follow along with to energize us!
Please consider starting you own thread in the Argosy sub-forum ( https://www.airforums.com/forums/f310/) to give us a little light relief from all the modern M B based upfitted vans!
03-25-2024, 07:48 PM
#97
_
, _
Originally Posted by martin300662
Hi Stevie
Yes! Please do start a thread on your 28'! I have a 1982 28' Airstream and I'm always interested in what other 28' look like!
May a Firefly land upon your shoulder
and bring you good luck, good fortune, and abundance.
