Old 02-24-2009, 02:44 PM   #1
1965 17' Caravel
Topsfield , Massachusetts
6v & 12v
I recently purchased a 1965 Caravel which I would like to tow with my restored 1940 GMC. The Caravel is 12 volt and my pickup is 6 volt. Does anyone have knowledge of this issue and how to make it work?
dockit1958 is offline   Reply With Quote
Old 02-24-2009, 03:13 PM   #2
SteveH's Avatar
Common Sense , Texas
The only practical way to do it that I am aware of is to change the GMC over to 12 volts.
Old 02-24-2009, 03:15 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Have you considered converting the truck to 12 volts? You will have to swap all the light bulbs, head lights included. Maybe installing a load resister for the radio if you want to keep the original.
The starter should work.
2004 Excursion 4x4
Old 02-24-2009, 03:20 PM   #4
Over59's Avatar
Putnam , Connecticut
Images: 37
A series of relays that close with 6 volts and allow the 12v item to be energized would be the over the top way to go. Forget about charging the trailer battery on going down the road. The wires aren't heavy enough anyway.
Over59 is offline   Reply With Quote
12v
2007 25fb 12V electrical problem Diego2 Electrical - Systems, Generators, Batteries & Solar 14 09-12-2017 04:17 PM
Can't find the 12V fuse bus... lilduckidan General Repair Forum 5 02-13-2012 12:35 AM
IDEA for a Refrigerator install with a 12v & solar fan BB 55 Bubble Refrigerators 12 01-30-2012 11:17 AM
Best 12V Dehumidifier palmer51 Winterizing, Storage, Carports & Covers 1 11-04-2011 10:33 AM
12v Wiring @ 31' Center Bath cuyd Lights - Interior & Exterior 4 06-01-2011 05:27 PM
