Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 04-13-2016, 10:10 AM   #1
RBonney's Avatar
1983 27' Excella
1990 34.5' Airstream 345
Spring Lake , Michigan
345 LE Drive shaft
Just wondering if this is common to see the splines or should this have a boot of some sort. Any input would be great. Thanks Click image for larger version
Name:	ImageUploadedByAirstream Forums1460563795.744817.jpg
RBonney is offline   Reply With Quote
Old 04-13-2016, 10:15 AM   #2
. , At Large
Originally Posted by RBonney View Post
Just wondering if this is common to see the splines or should this have a boot of some sort. Any input would be great. Thanks Attachment 260630
That's pretty much as it should be.
Old 04-14-2016, 08:58 AM   #3
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Need some spline available for the travel of the rear suspension. But mine too seems to have a lot of spline exposed.
Could grease it.
Cheers Richard
tevake is offline   Reply With Quote
Old 04-14-2016, 02:38 PM   #4
Could grease it.
Cheers Richard
I think any exposed grease is just going to coat the bottom side of the floor
1975 24' Argosy Motor Home
Old 04-15-2016, 10:33 AM   #5
1977 31' Sovereign
Lynnwood , Washington
It's supposed to be that way. The center yoke hasta slide on the splines you're looking at.
If you crawl under your rig at freeway speeds, you can see how this actually works. LOL
Tom
TomKirk is offline   Reply With Quote
Old 04-15-2016, 04:39 PM   #6
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
I think a go-pro camera would be safer ! Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 04-15-2016, 05:34 PM   #7
. , At Large
Aw, c'mon! Where's your sense of adventure?
Old 04-15-2016, 06:09 PM   #8
bobmiller1's Avatar
It left about 30 years ago !
Old 04-16-2016, 07:17 PM   #9
While you are under there, take a good look at the carrier bearing and surround and grab the U- joints and give them a hard shake to check for play.
Replacing these parts along with balancing the whole assembly is the best improvement I've made yet to the running gear of my coach. Took so much vibration out of the ride.
Cheers Richard
Drive Shaft and transmission test Chuckles Mechanics Corner - Engines, Transmission & More... 19 02-16-2010 07:17 AM
Disconnect Drive Shaft smily Airstream Motorhome Forums 2 02-23-2004 05:51 AM
Instalation of a new drive shaft saxonsraven Airstream Motorhome Forums 5 10-28-2003 08:45 PM
one piece drive shaft john hd Tow Vehicles 11 02-22-2003 11:48 AM
U joints and drive shaft thenewkid64 Mechanics Corner - Engines, Transmission & More... 2 07-13-2002 04:07 PM
